Price Check Kubota L35
/ Kubota L35
Suit yourself. I'm just that kinda guy!! Do my best tomorrow. Wanted to try it before it got totally dark.Still figuring out the front wheel drive. Great traction even from the R4s. Much more capable than I imagined. I think I lucked out and made the right choice.Sometimes I'm lucky. Glad I didn't buy a new off brand. Doubt this will be worth much less 10 yrs from now.
/ Kubota L35
Anyone got recommendations on some super bright flood work lights. Need 4 . 2 front and 2 rear. Willl install another alternator if necessary to run them. Gotta see. Days too short.
/ Kubota L35 #23
Good luck with your L35 , I added 4 halogen on mine and the did a good job lighting it up, if I was to buy them today I would get the led lights
/ Kubota L35 #24
All you would need is the toplink, side links and the two bars. All the other hardware is on the tractor, including the hydraulic cylinder to lift the 3PH. I would imagine them hard to find used but no more than a couple hundred new if I were to guess.
Just so you know the 3pt parts new are well over $1k. It has been a real problem for people buying used TLB were the parts were not included.
MarkV
/ Kubota L35 #25
MarkV
Wow, someone is making some real profit off them!
/ Kubota L35
Going to switch to the own and operate forum now that I got one. Sent it back for no front wheel drive. Said the coupler came off the drive.Back tomorrow.Gotta find the level and fill plug in the front axle.
2018 MACK CXU (PINNACLE) (A63569)
2018 MACK CXU...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
1993 Ford LS9000 Tri-Axle Dump Truck (A61573)
1993 Ford LS9000...
2018 Peterbilt 579 Sleeper 72" Sleeper (A62613)
2018 Peterbilt 579...
2021 Ford F550 4X4 Service Crane Truck (A62613)
2021 Ford F550 4X4...
2001 Eager Beaver 50 Ton Hydraulic Detach Lowboy Trailer (A64047)
2001 Eager Beaver...
