Kubota L35 Owners, Backhoe Valve Function?
   / Kubota L35 Owners, Backhoe Valve Function? #1
JG92979
Meriden, CT
Kubota L35, Bolens 750 1254, Ford 9N, Cushman
Hi I have a L35 Kubota, which is a awesome machine in my opinion, and I have a question on the function of the backhoe controls. I've owned it for 7 years and I have done some impressive work with this little machine and have been using it like this and never ran across another one that I could try so I don't know if this is the way its supposed to be or if its just my machine. My problem is the up-down/left-right backhoe lever has no variable control its like a on/off valve and is very hard to operate. The in-out/curl-dump stick works perfect with nice variable control. I've been to the dealer to see if there is a TSB or anything on this issue and they looked at me like "A what...?" and quoted me $1600 for a whole new valve body. I'm not buying it, I've changed valve sections before by myself, its not that hard if that IS my problem. There is no obsctrctions and I WD40ed the linkage so if there is a problem its internal. I'd really like to nail the problem and fix it without throwing money at nothing. I've have thousands of hours on backhoes and heavy machinery and use something daily and I can't let anyone else use this machine because of its uncontrolable jerkyness, someone can get hurt or wreck something if they don't have any expirience. Is anyone elses machine like this?
I recently demoed a JD 110 I was considering upgrading to. The backhoe works amazing, I was actually really impressed. I wish I could say the same for the loader and tractor itself. IDK if anyone has ever used one but the hydro 2 pedal system is retarded with having to run the rpms WOT and I just don't like the way that works when you are trying to used the front bucket for loader work, u forget what pedal is which and the engine is screaming. I think if you were running a 3pt hitch implement for a long period of time your leg would cramp up holding the pedal down. I love my L35, its simple and basic and its like running every backhoe ever made with the shuttle on the column and GST, and if I got to ride the clutch its just like driving a car cause there is a gas pedal on the right too. NO SALE!
Any help would be appreciated. Thanks.
   / Kubota L35 Owners, Backhoe Valve Function? #2
I have an L35 and though it's not the smoothest to operate I sure don't notice a difference in the two controls. I'd say if both controls don't have equal variables then somethings likely wrong.
Edit: Here is a short video of my L35 BH in action. Unfortunatly no shots of the controls. Hope it still helps.
   / Kubota L35 Owners, Backhoe Valve Function? #3
Have you changed any fittings on the work ports?
Some BH functions use restrictors to slow things down, and they might be missing on yours.
You might check your parts manual and see if they were used on your BH, and if not, you might try some restrictors, or needle valves.
It is probably a stacked valve, and you can replace a spool section if necessary.
Cool video, but i can't tell the operation of it. When you do 2 functions like swinging and dumping and stop dumping the swing gets all the flow and takes off. Same thing if you are raising the boom digging a ditch. I had the cover off it a while back, didn't see anything wrong. I was thinking about swapping the lines next chance I get on the up/down in/out functions to see if it makes a difference. Thanks.
   / Kubota L35 Owners, Backhoe Valve Function? #5
JG92979,
I am a proud L35 owner also.
As to your question, both my wobble joysticks have variable control. There are circuits that have what I'll call priority, but both of mine allow for a very fine control or feathering of movement.
For you to say that it is all or nothing, would certainly indicate to me some type of internal valve problem.
I hope you are able to find and fix your problem for a reasonable amount of money. When you get it working as it truly should, you will REALLY enjoy using your backhoe.
Best of luck
71059 (A49346)
71059 (A49346)
Nissan 5k Forklift (A51039)
Nissan 5k Forklift...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2015 Ford F-450...
2019 HINO 155 16FT BOX TRUCK (A50505)
2019 HINO 155 16FT...
Kubota SVL95-2 High Flow Cab Skid Steer (A51039)
Kubota SVL95-2...
2018 PJ 30+5 GOOSENECK TRAILER (A50854)
2018 PJ 30+5...
