Oil & Fuel Kubota L345 Transmission fluid
   / Kubota L345 Transmission fluid #1
carlubu1
Yazoo City, MS
Kubota L345
Manual for kubota L345 says transmission fluid should flow freely from check plug, but does not show where the plug is located. There is a small plug on left side below gear shift. Is the check plug?
   / Kubota L345 Transmission fluid #2
On my L345 I've never have taken the plug out. There's also a dipstick - top of trans close to the front of the seat - has a rubber button handle. If tractor has been painted sometimes the dipstick is painted over too.
Thanks. I've checked the PTO dipstick located where you described, but the operators manual says that transmission fluid should flow out freely from the check plug. It shows the drain plugs, but not the check plug.
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2001 Blaw-Knox PF 150 Paving Machine (A52384)
2001 Blaw-Knox PF...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2016 RAM 3500 HD SERVICE BODY TRUCK (A52576)
2016 RAM 3500 HD...
Starcraft Starlite 22ft Travel Trailer (A51694)
Starcraft Starlite...
