Oil & Fuel Kubota L345 Transmission fluid
   / Kubota L345 Transmission fluid #1
carlubu1
Yazoo City, MS
Kubota L345
Manual for kubota L345 says transmission fluid should flow freely from check plug, but does not show where the plug is located. There is a small plug on left side below gear shift. Is the check plug?
   / Kubota L345 Transmission fluid #2
On my L345 I've never have taken the plug out. There's also a dipstick - top of trans close to the front of the seat - has a rubber button handle. If tractor has been painted sometimes the dipstick is painted over too.
Thanks. I've checked the PTO dipstick located where you described, but the operators manual says that transmission fluid should flow out freely from the check plug. It shows the drain plugs, but not the check plug.
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2025 New/Unused Wolverine Hydraulic Skid Steer Pallet Forks (A51573)
2025 New/Unused...
2006 Ford Fusion SE Sedan (A51694)
2006 Ford Fusion...
2002 Kenworth T800 Truck, VIN # 1XKDD49X72J898126 (A51572)
2002 Kenworth T800...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
1990 Ingersoll Rand 185 Towable Diesel Air Compressor (A52377)
1990 Ingersoll...
