Kubota L3400DT
   / Kubota L3400DT #1
cmiller
Have looked at this tractor for use on small farm of 34 acres. Currently have older JD. Is the Kubota L3400DT a good option? Any Virginia dealer recommended?
   / Kubota L3400DT #2
Would help to know where in VA you are, and what the lay of the 34 acres is as field is not the same as woods, etc.. BobG in VA
   / Kubota L3400DT
In Rockfish Valley, Afton. Rolling hills to bottom fields, 40% woodland with stream. Tractor is used for mowing, garden cultivation and clean-up in wooded areas.
   / Kubota L3400DT #4
I live in Lynchburg and our 50 acres are in Pedlar Mills. Very hilly terrian. We have a L4300DT that we bought over the L3000DT because of the flat platform. I pull a 6' rotary cutter with it no problem. I haven't looked at the L3400DT but I heard it was a great addition to the line.
I'm sure I would be pleased with the L3400DT and we may have went that way if they had them last year when we got the L4300DT. I love this tractor and haven't looked back.
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A52748)
Toyota 6FGU25...
2018 Caterpillar CS54B Smooth Drum Vibratory Dirt Compactor (A51691)
2018 Caterpillar...
2013 Toyota Prius Hatchback (A50324)
2013 Toyota Prius...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2004 Mercedes E320 Sedan (A50324)
2004 Mercedes E320...
