Kubota L3400DT PTO not working
   / Kubota L3400DT PTO not working #1
kouterbrown
Mauriceville Texas
Kubota L3400DT
Just a little FYI i let my neighbor barrow my tractor to brushhog at his deer lease "Mistake" after running out of shear pins he installed a Grade 8 bolt Well i pulled shifter cover off gear box and pulled PTO lever gears are meshing well & turning BUT output shaft is not turning. Pulled output shaft out of the back of the tractor & it & the splined coupling are fine, looking for any help or advice on splitting the tractor just behind the gear box or any one who has experianced this problem.
   / Kubota L3400DT PTO not working #2
I replied to your other similar thread. I think you might have a pto clutch hub stripped out.
   / Kubota L3400DT PTO not working #3
Yes I agree. If the pto shaft isn't broken and the gears look good, not much else it can be.
   / Kubota L3400DT PTO not working #5
Incidents like this remind me to never, ever, loan out my tractor. How much do you guys think it will cost to fix, at the dealer?
(10) 20' Continuous Fencing Panels (A50515)
(10) 20'...
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A51691)
1991 Grove RT740B...
KJ 20'x12' Livestock Metal Shed (A50121)
KJ 20'x12'...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
E-Z Trail 672 Head Cart (A50514)
E-Z Trail 672 Head...
2017 Schulte FX107 84in Rotary Cutter Attachment (A50322)
2017 Schulte FX107...
