Kubota L3400 QA Bracket.
   / Kubota L3400 QA Bracket. #1
digicamnut
South East Teaxs
I'm fixin to buy a Kubota L3400 with the QA Bracket. Can I use most skid steer attachments with my tractor? I'm getting forks as part of the deal.
   / Kubota L3400 QA Bracket. #2
You will be able to use many skidsteer attachments with your L3400, but you have to be aware of the weight of the attachment and how it will limit your lift capacity. For example, your L3400 FEL has a lift capacity of around 1000#... if you were to try to use a skidsteer grapple that weighed 650# it wouldn't be of much use since it would only leave you around 350# of capacity to lift whatever you were trying to grapple.
Many skidsteer attachments also require additional hydraulics, and/or high flow rates that your tractor may not be capable of.
You should be fine with a lightweight set of forks, grapple, etc.
Westbrooklawn,
I noticed that you had the woods bh80 do you prefer the woods over the kubota?
   / Kubota L3400 QA Bracket. #4
digidcam -
From all the searching and reading I did on this site, I felt the Woods backhoe was better quality, and had a better track record than the Kubota hoe (dipperstick problems, etc.), so that is the one I went with. I am very pleased with the Woods... it does very good for it's size. If you have ever operated a dedicated full size backhoe you may be dissappointed in a CUT backhoe... just remember it has it's limitations. You can do about all you want to with it, but it just will just take much longer than a full size hoe.
Thanks for the info. I'll call tomorrow and see what the price difference is.
Craig
2012 Ram 1500 Crew Cab Pickup Truck (A50323)
2012 Ram 1500 Crew...
2016 GMC Terrain SLE1 SUV (A50324)
2016 GMC Terrain...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
2005 Chevrolet Colorado 4x4 Pickup Truck (A51692)
2005 Chevrolet...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2016 Ford F-450...
2016 Ford Explorer...
