Buying Advice Kubota L3400 HST Tractor Review (9 Years and 506 Hours):
   / Kubota L3400 HST Tractor Review (9 Years and 506 Hours): #1
Junguda
Tennessee
Kubota L3400 HST
In 2007, an L3400 HST with FEL, BB, RFM and Rotary Cutter was purchased for about $21k in Middle Tennessee. The tractor is used on a 50 acre parcel that has been left in timber for about 40 acres. Parcel is hilly, with 300 feet of elevation from lowest to highest points. The attachments are Woods RD7200, BB60, and very heavy 6 Box Blade (Can't remember the brand). It has R4 (Commercial) tires not loaded. 506 hours are on the tractor, and in return for the great advice received from Tractor By Net, I'd like to share a review that might help potential buyers.
What has broken:
1) Peep Window for Hydraulic Oil Level - This was a plastic screw in window that made it easy to check fluid level (Located below the seat on the transmission tunnel). I didn't realize it had broken, until Hydraulic fluid had leaked out. It was an easy fix, dealer had the part on a Saturday morning. The part cost about $25, and $50 for Hydraulic fluid.
2) Hydraulic Return Hose - After my son worked the loader to move creek gravel, I got on and noticed a shudder (Jerking) in the loader operation. Googled the problem, and a lot of L3400 owners posted about it. There's a 90 degree bend in a return line (About the size of a radiator hose), that vibrates a crack on the inside bend. The part cost $35, but was not in stock (Ordered). Install was easy with two hose clamps. Very little Hydraulic fluid leaked out, as this is not a pressurized line.
3) PTO Engage Cable (Shift) - This cable has broken twice. It gets frayed at the top, and eventually will not engage the PTO (Annoying). Evidently, Kubota knows about the problem, and they ship a re-designed shift assembly with the replacement cable. Unfortunately, I was lazy and kept the original shift bracket, so the new cable got frayed and broke again. The cable and new housing ship for about $35 (Parts not in inventory at dealer), so $70 was spent on this issue.
4) PTO Clutches Stick (Biggest Problem) - After about 300 hours, the PTO engage cable could be moved to dis-engage (Off), but the PTO would continue to spin (Dangerous). I googled it (Again), and this is another problem Kubota is known for. Posters say it is due to heat in the clutches (Warping them, so they stick engaged). Fix appears to be expensive, so I've found that if you dis-engage the PTO to off, and drive up to a steep incline (20-25 degrees), then stop and push clutch in, it will usually release (PTO stop spinning). No idea why this works, but it is cheap.
5) HST Rocking Pedal Sensor - At 400 hours, the key was turned, lights came on, but no starter engaged. Charged the battery (Not it). Took the starter off and tested it (Not it). Moved the pedal to center (straight up), and it started right up. Should have Googled it first ($0 cost). There's a sensor on the pedal for safety (I assume).
6) Retractable Seat Belt - Kubota is so proud of these things, I hate to tell them they don't work. Sticks and debris get into the re-coil mechanism, and they stop rewinding. So the belt gets hung over my steering wheel, when I get off. I cleaned out the mechanism one time, but it got blocked in a few days use (No Cost).
7) Tractor Rolled into Creek - OK technically this is not a break, but it was a problem, and since I'm writing the review. It took a come-along snatched to a walnut tree and log chains looped around the ROPS top to bring it up on two wheels and out of the creek bed (Nasty work). No damage. The side fenders, hood and everything were in tact (No bends or dents).
What I'd Do Differently:
1) Load Tires - There have been some really close calls, and I plan to fill the tires this Spring
2) Ag Tires (Possibly) - The R4s wear like iron, and they get traction 99% of the time, but when they break loose on a wet hill side, the ride/slide is not fun.
3) Telescoping Lower Links on 3-Point - The L3400 does not have telescoping links, so changing out the rotary cutter for the box blade requires a 6-foot pry bar to line up the pins.
4) Deeper Cup Holder - The L3400 cup holder is rather shallow, so if you put cigars or a cell phone in it, a low branch or jolt will knock them out onto the ground.
5) Cigarette Lighter for 12 volt access - There's no socket for your air pump or iPhone charger
6) Get Rid Of Cruise Control - Never use it. It sounds good, but I like to be in control.
7) Look Closer at Used Tractors - We got new, because I didn't know much about tractors, and had been told stories of snapped front axles (Due to FEL work). In hindsight, those fears weren't justified, and a good used tractor might have been a better option.
What I'd Do The Same:
1) Get a Tractor - Business folks might say averaging 55 hours of use per year, doesn't justify spending $21k on a tractor. You could pay for mowing ($35 per acre) with the interest on $21k; not counting the diesel and maintenance costs. Good point (But I'd still get the tractor).
2) Get A Kubota - It's had annoying breaks, and I believe John Deere, Case, New Holland, Mahindra and others make fine tractors. I'd probably buy the Kubota again, but I'd consider others.
3) Buy An L3400 - A lot of owners trade their first tractors for larger machines. I would not.
4) No Cab - The ROPS barely fit through low branches, a cab would have been destroyed.
5) Buy From the Same Dealer - My dealer has been great. The salesman explained slip clutches and the value of a rotary cutter (He was right). They've always had my fluids, filters and most parts in stock.
6) Get Advice from Tractor By Net - These folks have been great. The wisdom in this forum is priceless.
   / Kubota L3400 HST Tractor Review (9 Years and 506 Hours): #2
Nice write up. I have a L3700 that is about 6 years old and have had minimal mechanical issues. The jerky 3 point hitch is what it is, I put shims in the loader valve to add a bit more lift capacity and very early in ownership the pin in the BH broke that mangled the boom (completely replaced under warranty ). As far as what I would do different ? ...probably get one with a enclosed cab..
   / Kubota L3400 HST Tractor Review (9 Years and 506 Hours): #3
I'd clean that seat belt mechanism out again. I took the one off my 99 L3710, don't know if it's the same. I got it cleaned out very well and lubed it. It's been working fine ever since. When the tractor rolled into the creek bed, was someone on it? I agree with loading the tires.
Kevin
   / Kubota L3400 HST Tractor Review (9 Years and 506 Hours): #4
Nice write up. My second hand L3710 has been very reliable. Do load the tires, as you will notice an immediate improvement. In fact, my belief is anything other than a lawn mower should have tires loaded. Take care of that machine and it will reward you with decades of good service.
   / Kubota L3400 HST Tractor Review (9 Years and 506 Hours): #5
Appreciate the review; it was well thought out and will be helpful for many. If you ever decide to go the telescopic arm route, consider a quick hitch as another option. I have the Pat's and find it much easier switching out my attachments.
   / Kubota L3400 HST Tractor Review (9 Years and 506 Hours): #6
The only "issue" with my L3400 HST has been small amount of hydro fluid that leaks out of the overflow under the seat when working the tractor hard on hot days. Just over 400 hrs, love this tractor!
   / Kubota L3400 HST Tractor Review (9 Years and 506 Hours): #7
I
What has broken:
#2 above reminds me of when I used to borrow my old neighbor's L3400 for mowing and light 3Pt work, as my tractor is too heavy and I'm too lazy to remove the hoe.
The darn hose cracked on my watch, so it was me who repaired it.
Featherweight L3400 was scary till I had my neighbor get his tires loaded.
If you think I'm a bad neighbor, This bad neighbor sure did a lot of digging and snow plowing to more than offset the occasional tractor "borrow"
   / Kubota L3400 HST Tractor Review (9 Years and 506 Hours): #8
Great review! Thanks. Comment...I was surprised to see that you have had these many problems. I believe that should not be the case except possibly the first one or two production years of an entirely new model...and then covered under warranty. Spend the money and get the PTO clutch fix installed! My experience owning another brand tractors, both smaller and a bit larger, has been much better. As for the cab / open ROPS issue, if there is any way an operator can avoid overhanging trees most of the time, a cab is really worth while. Again, great review. Do upgrade the PTO clutches and maintain the seat belt and wear it.
   / Kubota L3400 HST Tractor Review (9 Years and 506 Hours): #9
As a L3400 owner, I was interested in the observations/report. I did put spacers (1.75") on my rears, and I pretty much always have a weight box on the rear.
I avoid loaded tires, since sometimes leaving impressions on "lawn", even with turf tires, is a problem when it is wet. (I lighten or remove the weight box when I need to travel over wet lawn areas, if I can.) I appreciate why loaded tires are good, though, since our L3130 had them, and it was fine without anything hanging on the rear for most work. No problem with the return hose, and I believe the PTO cable was replaced by the first owner, from the looks of things. I am at 750 trouble free hours (although it had 540 when I bought it) and, now that I think about it, I use it about 100 hours a year. Several heavy snowfalls would change that, though. I am considering getting a set of R-4 tires/wheels, since I am spending more time operating in woods.
   / Kubota L3400 HST Tractor Review (9 Years and 506 Hours): #10
We have almost a 1,000 hours on the L3400 and it has been a great tractor. Loading the tires is a definite since its pretty large to be on a lawn. As for the lowers links, stick the bucket lip into the ground and use the curl of the bucket to rock the tractor back and forth to line the pins up.
2016 Generac MCP5538WT 2in Diaphragm Water Pump (A41182)
2016 Generac...
2020 MACK PINNACLE P164T (A45046)
2020 MACK PINNACLE...
We do NOT accept credit cards as payment. (A44501)
We do NOT accept...
2008 CAT 953D Loader (A42203)
2008 CAT 953D...
2023 Komatsu WA 270-8 Wheel loader (A39855)
2023 Komatsu WA...
M&W 1815 Rotary Hoe (A39855)
M&W 1815 Rotary...
