kubota l3350 will not move and bucket will not work
   / kubota l3350 will not move and bucket will not work #1
bigrome
ravenewood
kubota l3350
I have kubota l 3350 tractor with loader and the tractor moves somethings but not alot the loader works for min I has shuttle shaft I move the lever forward and reverse nothing its like the hydraulic pump is out the bucket amd the 3 point hitch doesn't work and we just got it fixed I thinking not please help
   / kubota l3350 will not move and bucket will not work #2
Have you checked the obvious, fluid level, all filters, correct fluid?
What kind of pressures are you seeing?
Do you even know if the pump is turning?
Hydraulics:
Type: open center
Capacity: 11.4 gal [43.1 L]
Pressure: 2500 psi [172.4 bar]
Valves: 0 to 2
Pump flow: 9.3 gpm [35.2 lpm]
   / kubota l3350 will not move and bucket will not work #3
Welcome to TractorByNet!
I moved your thread to the Kubota Owning & Operating forum. :)
   / kubota l3350 will not move and bucket will not work #4
........we just got it fixed I thinking not.....
The main hydraulic pump is gear driven from engine - if they fail it's most often gradual as they get worn. What was it doing before you had it fixed? Check the oil level first - it's a big reservoir, may just be low.
   / kubota l3350 will not move and bucket will not work #5
I have the same tractor l3350 doing the same thing,did you figure out what the problem was? If so what was it. thanks, Ron
2020 Chevrolet Tahoe SUV (A48082)
2020 Chevrolet...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2019 Chevrolet Tahoe SUV (A48082)
2019 Chevrolet...
2012 Chevrolet Impala Sedan (A48082)
2012 Chevrolet...
2025 JMR 36in Mini Skid Steer Bucket Attachment (A50322)
2025 JMR 36in Mini...
2006 FAE Mulcher (A49461)
2006 FAE Mulcher...
