kubota l3350 will not move and bucket will not work
   / kubota l3350 will not move and bucket will not work #1
bigrome
ravenewood
kubota l3350
I have kubota l 3350 tractor with loader and the tractor moves somethings but not alot the loader works for min I has shuttle shaft I move the lever forward and reverse nothing its like the hydraulic pump is out the bucket amd the 3 point hitch doesn't work and we just got it fixed I thinking not please help
   / kubota l3350 will not move and bucket will not work #2
Have you checked the obvious, fluid level, all filters, correct fluid?
What kind of pressures are you seeing?
Do you even know if the pump is turning?
Hydraulics:
Type: open center
Capacity: 11.4 gal [43.1 L]
Pressure: 2500 psi [172.4 bar]
Valves: 0 to 2
Pump flow: 9.3 gpm [35.2 lpm]
   / kubota l3350 will not move and bucket will not work #3
Welcome to TractorByNet!
I moved your thread to the Kubota Owning & Operating forum. :)
   / kubota l3350 will not move and bucket will not work #4
........we just got it fixed I thinking not.....
The main hydraulic pump is gear driven from engine - if they fail it's most often gradual as they get worn. What was it doing before you had it fixed? Check the oil level first - it's a big reservoir, may just be low.
   / kubota l3350 will not move and bucket will not work #5
I have the same tractor l3350 doing the same thing,did you figure out what the problem was? If so what was it. thanks, Ron
2009 HINO 185 18FT BOX TRUCK (A51219)
2009 HINO 185 18FT...
1999 Pierce Quantum Fire Truck (A48081)
1999 Pierce...
2016 Chevrolet Impala LT Limited Sedan (A48082)
2016 Chevrolet...
Lincoln Electric Vantage 300 Welder/Generator (A49461)
Lincoln Electric...
2004 CATERPILLAR 963C CRAWLER LOADER (A51242)
2004 CATERPILLAR...
2014 GOOSENECK DRIVER SIMULATOR TRAILER (A50854)
2014 GOOSENECK...
