kubota l3250 new toy, restoration, 3 point linkage fault
   / kubota l3250 new toy, restoration, 3 point linkage fault #1
oil burner
Portsmouth, hampshire uk
kubota L3250
HI, husband has started on a restoration project of L3250 Kubota.
the three point linkage rises and falls ok but will not lift anything, any suggestions on where to start looking?
thank you
   / kubota l3250 new toy, restoration, 3 point linkage fault #2
May just be low hydraulic pressure due to low level or a clogged filter.
   / kubota l3250 new toy, restoration, 3 point linkage fault #4
Does it have a Front End Loader? If it does, does it work fine?
When the 3ph doesn't lift, does the tractor sound like it's going into bypass or sound like it's straining or lugging down the engine?
Thanks for you interest, yes front loader works fine, now the flow and return are the right way round which some numpty wrongly connected!
Link arms come up with no strain or hydraulic bypass operation and no odd noises.
Will not lift anything but once up will stay up ok.
Kind regards, Neil
   / kubota l3250 new toy, restoration, 3 point linkage fault #6
So raise the three point hitch up to the top and shut off the tractor, does the 3ph stay up?
You say "stays up ok" (I assume with the tractor running) if you put any down pressure on the 3ph (weight of your arm) does it just falls with little or no resistance? or can you stand on it and it still holds up?
IF it doesn't, Try that again with someone moving the loader up and down and curling it... (thinking if you already found hoses in the wrong place once...)
Let us know how it goes... If the loader is working correctly, the pump is good. Hydraulic oil goes to the front end loader first then 3 ph. Are there any remotes? Are there any extra hydraulic connections for rear implements or for the front (like for a grapple or snow plow)??
   / kubota l3250 new toy, restoration, 3 point linkage fault #7
Sounds like the O rings between the 3pt control valve and rockshaft or the 3pt relieve valve.
HI, Once link arms are raised the will stay raised, at the moment there is a link box on the back with 10 concrete blocks in it!, but to achieve that, I had to manually assist the box to the raised position before loading the blocks of course ;)
there is a tipping pipe but not connected anything to it yet.
So, the linkage stays up with the engine turned off.
thanks for your interest!
I don't think I have found either of those valves yet, is it something a novice can tackle?
I have just discovered the four wheel drive is not working either.
:confused:
thank for your interest.
   / kubota l3250 new toy, restoration, 3 point linkage fault #10
4x4 - The front drive shaft could have stripped out, not that bad to tear into that... from under neath. So you know how to engage the 4x4? I'm not sure about that model...
I'm with LeeJohn, above, the three point hitch control needs to be rebuilt (most likely). Replacing "O" rings... look at the linkage to raise and lower the hitch.
If it doesn't have Remotes, yes this is some thing that a novice can add. I did it and I had no clue what was needed when I started... we can give you the basics and link to other threads about it.
Need to get the tractor running first ;)
2008 CATERPILLAR 430E BACKHOE (A51242)
2008 CATERPILLAR...
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
UNUSED AGT QUICK ATTACH DROP HAMMER (A51244)
UNUSED AGT QUICK...
2013 Ford F-150 XLT - EcoBoost, Blown Engine, Good Parts Truck (A51039)
2013 Ford F-150...
IH Farmall 706 Tractor (A50514)
IH Farmall 706...
2020 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2020 Ram 1500 4x4...
