Comparison Kubota L3200 vs. John Deere 3032E
   / Kubota L3200 vs. John Deere 3032E #1
rwhiterfi
DeWitt, AR
Kubota L3400
Just sold my JD 850 gear and purchased a new Kubota, did some extensive research comparison between the JD and Kubota before making my decision, just wanted to share some of my observations. Actually I checked on NH also, but they were priced way out of the same range as the JD and Kub. I priced and compared a Kubota L3200 HST to a JD 3032E, and here are some things that helped me choose the orange:
1. Physical size and tire size, Kubota won.
2. 3 range HST (Kubota) vs. 2 range.
3. Quick detach loader (Kubota) vs. quick detach bucket only (JD)
4. FEL bucket lift height, Kubota was almost a foot higher.
5. Top speed (Kubota was almost 2mph faster)
6. Electronic fuel guage vs. in tank.
7. Kubota has cruise control for HST.
8. The biggest thing for me, was the JD body was almost entirely plastic, compared to metal on the Kubota, which had only a short section over the inst panel. The JD hood, fenders, and even the floorboard and step were all plastic. No wonder the weight difference! And what will the plastic look like in a few years of being out in the sunlight, or being scratched? You sure can't re-paint it!
The only thing that I actually liked better on the JD was the two pedal HST control, vs. the single, rocker pedal on the Kubota. I have seen many posts on here and other places of folks complaining about the jerky 3PH on the Kubota, and mine did that the first time I used it, but it has a valve control between the seat and floorboard to adjust the 3PH speed, I screwed that in a couple of turns and fixed it just like that.
IMG-20120630-00181.jpgAnd I actually ended up buying a L3400, they are closing those out, so I was able to pick up a 34 hp tractor instead of the 32 hp for $1000 less money. I paid 16k for the L3400 (dealer cost, or so they said) with a LA524 FEL. I added a remote hydraulic for 750 more. I have only had the tractor for about a month, but I am very, very pleased with it so far.
   / Kubota L3200 vs. John Deere 3032E #2
Congrats, you made a good decision. If I was getting one of the two models, the deciding factor for me would be the extra weight! Can't believe that JD made it so light! Without that weight, you just have an expensive lawn mower.
One thing, did you check the jerky 3 point hitch? I assume you are aware of this? It can be a pain, so just letting you know.
Congrats again :thumbsup:
   / Kubota L3200 vs. John Deere 3032E #3
Yes, alway's check with a load on the 3 point. Martain, Do you know why JD is building these machines so light?
   / Kubota L3200 vs. John Deere 3032E #4
Congrats. Nice tractor!
I looked at the JD3032E also and got more tractor for less money with the L3800.
   / Kubota L3200 vs. John Deere 3032E #5
I agree, very nice tractor and a nice size. Have a good time with it.
   / Kubota L3200 vs. John Deere 3032E #6
$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ They wanted to build an economy tractor, they just built it too dam cheap in my opinion.
   / Kubota L3200 vs. John Deere 3032E #7
Good choice! In the under 50-60hp CUT range I don't think the Kubota's can be beat, IMHO. As far as the rocker pedal, I'm not sure exactly how it's made on the L3200 but on the L3940 it becomes second nature real fast. We have an X720 JD GT and now the twin pedals seems out of place compared to the Kubota.
   / Kubota L3200 vs. John Deere 3032E #8
We have a mix of pedal layouts on different products, but I personally find it really unnatural to push forward to go backwards. I just does not feel right to me.
   / Kubota L3200 vs. John Deere 3032E #9
Try pushing down instead..
   / Kubota L3200 vs. John Deere 3032E #10
In principle I like the side by side pedals better, however in practice I find the rocker peddle design to be less oopps wrong peddle prone.
Grats on the tractor. Have fun, stay safe.
2014 Ford Escape SE, Eco Boost (A52384)
2014 Ford Escape...
2016 HAMM HD+ 120I SMOOTH DOUBLE DRUM ROLLER (A51246)
2016 HAMM HD+ 120I...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
JOHN DEERE 661R LOT NUMBER 106 (A53084)
JOHN DEERE 661R...
1/4 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/4 '' Wolverine...
2025 New/Unused Wolverine 48in Skid Steer Trencher (A51573)
2025 New/Unused...
