Kubota L3130 Pictures...
   / Kubota L3130 Pictures... #1
Dave___in___CT
West-Central CT
Kubota L3130, LA723 Loader, BH90 Backhoe, Curtis Cab, || '82 Gravely 8199KT garden tractor
Hi...
As requested... here's a link to some pictures of my new Kubota L3130
There's 1 picture in the Attachment of this post too...
I spent time marking things on the tractor with white & yellow paint pens to make 'em easier to find...
...things like engine oil & hydraulic oil drainplugs... dipsticks... fluid fill points... 3-point-hitch parts... etc...
Anyone else do this ? /forums/images/graemlins/confused.gif
Also closed up un-needed openings into the cab with weatherstripping tape to make it a little more airtight for the heater....
The Curtis cab roof has about 8-10 bolts that penetrate it... There's plastic washers under the rounded bolt heads to supposedly prevent water from entering...
As an extra precaution... I used bottle caps... sprayed oil on 'em to prevent silicone caulk from sticking... filled 'em with clear silicone caulk... then placed the filled caps over the bolt heads to seal all around 'em... hopefully the caps will come of off the silicone and leave nice silicone seals...
Next... I'm gonna add to 2 LED side marker lights to the lower front sides of the tractor... wired into the brake light wire so they are on when the lights are turned on...
Hope I get a chance to wax the tractor soon... already washed it after the sandy/salty road trip home from the dealer's...
Only missing part is the rear window wiper... should show up soon...
...oh... maybe I'll add a radio at some point... but don't wanna drown out the sweet diesel sound !
Dave...
   / Kubota L3130 Pictures... #2
Nothing better for the soul and the mind then a new toy! looking good Dave!
   / Kubota L3130 Pictures... #3
That is a nice looking machine. Now go move snow!
And what exactly do you mean by "marking things on the tractor with white & yellow paint pens to make 'em easier to find... "
Have fun....uhhhh, I mean work
   / Kubota L3130 Pictures... #4
Wow Dave
That is an impressive setup. I have a trailer similar to yours except with the gooseneck hitch. The other day I went to load up my M9000 for its 50hr service and it wouldn’t fit between the wheel wells. Tomorrow I’m going to look at deck over wheels gooseneck trailer. Hopefully the owner and I can come to an agreement. It looks like your tractor is also a snug fit. At least it will work I had to use the neighbors trailer.
Thanks for the pictures.
Eric
</font><font color="blue" class="small">(
)</font>
For example... the drain plugs under the tractor (5 on this machine) are the same color as everything else... dark grey...
...and some bolt heads are about the same size... not so easy to spot the drain plugs...
...so I paint the drain plugs and a circle around 'em a color that shows up... like white...
Trailer/tractor... yep... snug fit between the fenders... about 6" extra on each side...
A nice feature on this trailer... the 6' ladder ramps are kinda heavy... the manufacturer put a large coil spring on 'em to make 'em EZ to lower/lift...
Good luck with your trailer search...
The idea of the silicone caulk in the bottle caps over the bolt heads didn't work... after 1 full day... the silicone was still uncured... so I just applied the caulk freehand...
Thanks...
Dave...
   / Kubota L3130 Pictures... #6
Great looking rig! A lot of people would think I'm nuts, but, as an expatriate from the North, all that snow has me kind of jealous. Enjoy your new 3130! How do you like the Curtis cab?
Hi...
No chance to use it for snow removal yet... hoping for a big storm ! /forums/images/graemlins/smile.gif
Having the cab with heater will be great... finally out of the weather & warm !
Dave...
   / Kubota L3130 Pictures... #9
Sassafraspete,
Brown County. Nice part of the State.
Welcome to TBN. You need to fill out the rest of your profile. We are a nosy bunch
   / Kubota L3130 Pictures... #10
Nice looking setup you got there. It looks awesome!
SCAN TO RECEIVE TEXT UPDATES (A51246)
SCAN TO RECEIVE...
2019 CATERPILLAR 316FL EXCAVATOR (A51246)
2019 CATERPILLAR...
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
2025 INDUSTRIAS AMERICA FT510 5' X 10' HYD DUMP TL (A51247)
2025 INDUSTRIAS...
2006 CATERPILLAR 330DL EXCAVATOR (A51246)
2006 CATERPILLAR...
