Kubota l3130 HST with cab and FEL - switch issue?
   / Kubota l3130 HST with cab and FEL - switch issue?
Hawkeye, I checked the wiring as much as I can. Most is covered with plastic conduit and pretty secure. When I talked to the dealer they said the wire is usually not the problem unless it is mice chewed.
   / Kubota l3130 HST with cab and FEL - switch issue? #12
Did you check the hst pedal switch ? Maybe out of adjustment and shutting down the tractor
Is that the same thing as the neutral switch? I checked it for resistance and that was good. How do you check it for adjustment? I know it was threaded in and it seemed to be holding the pin into the switch at neutral.
   / Kubota l3130 HST with cab and FEL - switch issue? #14
On my l3800 sometimes I have to jiggle the hst pedal to start the tractor , So yes neutral switch
Opc timer switch coming tomorrow. Will let you know outcome. In the meantime
a comment on the mentioned PTO switch and neutral switch - both pass ohm tests, and I understand how they could cause a no start, but if tractor starts and I am sitting on the seat, the pedal can leave neutral and the PTO can be engaged. I wouldn't think they could cause shutdown unless I am missing something?
OPC timer did the trick. Thanks to all who helped!
Kraus Drive Over Fertilizer Conveyor (A50514)
Kraus Drive Over...
(4) HD 16' Pipe Gates (A50515)
(4) HD 16' Pipe...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52128)
2013 Doyle Dry...
2009 Chevrolet Cobalt Sedan (A50324)
2009 Chevrolet...
2008 JLG SKYPOWER 800AJ MANLIFT (A51242)
2008 JLG SKYPOWER...
Wooden Dump Barge Wagon (A50515)
Wooden Dump Barge...
