Kubota L3130 : Front Axle Vent
   / Kubota L3130 : Front Axle Vent #11
My bush hog has a pressure relief vent plug that looks just like this one. Mine has a small ball bearing that's held closed with a small spring. I like it because no matter how much water I go through I know it's not going to get in the gearbox.
   / Kubota L3130 : Front Axle Vent #12
My Kubota M6040 has a front axle vent. Screw in nipple right dead center top of the axle. Rubber hose goes up to small diameter metal pipe above the radiator. The metal pipe has a 180 degree bend and the very end is squeezed almost closed. I would guess that the squeezed end is so nasty mud dauber wasps won't build nests in the pipe.
   / Kubota L3130 : Front Axle Vent #13
Sorry, but who's tractor are you referring to?
(Mine did not have a vent for sure, but has one now)
I was just noting that my tractor does have the vent. I think many tractors are vented, it's just hard to see the vent. No one in particular...
   / Kubota L3130 : Front Axle Vent #14
I did not have a vent on the L2550DT so I added one. I drilled a 1/16th hole in the fill plug and then drilled a second hole in the outside of the plug to receive a 1/4" npt hose barb threaded fitting. I turned the threads off the hose barb fitting to match the hole diameter in the fill plug and inserted and then seated it in place.
From the hose barb I ran piece of 1/4" fuel up higher in the engine compartment. I added a small inline fuel filter that breathes both directions and another piece of fuel line to continue another few inches. the end of the hose has a screen to avoid the insects building inside it.
If I am going to let the axle "breathe", it may as well be clean air through the filter.
SAMSUNG REFRIGERATOR / FREEZER (A54757)
SAMSUNG...
RING 2 STARTS HERE @ 9:15 AM (A58375)
RING 2 STARTS HERE...
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
23018 (A55758)
23018 (A55758)
2019 Ford F550 Chassis (A55973)
2019 Ford F550...
