Kubota L3130 Front Axle Case
   / Kubota L3130 Front Axle Case #1
notimeforfear21
bakersfield, ca
kubota l3130
I have a kubota l3130 with a blown axle case seal and for the life of me i cannot figure out how to get the dang thing apart. If anyone can help that would be great pictures a HUGE plus. THANKS
   / Kubota L3130 Front Axle Case #2
My Kubota axle was very simple to disassemble, it should be nearly self-explanatory. Remove the 4 bolts and take the whole thing off and work on it off the tractor.
The seals do not blow, since there is no pressure in the axle, they just leak. Once you have it apart, I would replace ALL seals as well as the metal/rubber plug on the bottom. The plug wears and falls out at some point and it will quickly dump all your fluid.
Depending on the # of hours and what you see, you might also do all the bearings. The Kubota bearing prices are not bad, or you can find a local bearing supplier and purchase some quality US/Japanese replacements. At least in the 90s, these bearings were regular brand-name bearings and have the # on them so they're easy to cross-reference.
If it's the "pivot" seal, I believe that portion as well as the wheel hub requires a press to remove and reinstall.
I recommend reassembling with some Permatex Black or similar sealant, which will help minimize future issues.
   / Kubota L3130 Front Axle Case #3
You should be able to do a Kubota parts lookup on the web for your model to get a diagram. Somebody posted a cross section view along with an exploded view of a Kubota axle a week or so back when they had a leak. Not sure if it was the same series axle as yours but they might be similar enough to help you out. I think it was on this Parts and Repair forum.
   / Kubota L3130 Front Axle Case #4
Axle case seal is a pretty generic term, what seal actually is leaking?
2015 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2015 CATERPILLAR...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2012 CATERPILLAR 336EL EXCAVATOR (A51242)
2012 CATERPILLAR...
2012 SULLIVAN PALATEK AIR COMPRESSOR (A51222)
2012 SULLIVAN...
