Kubota L3130 : Can someone confirm I have proper sized turf tires?
   / Kubota L3130 : Can someone confirm I have proper sized turf tires? #1
hendr1x
2003 Kubota L3130
Hello everyone,
I just wanted to be 100% safe with my 4wd..can someone confirm that these are the proper tires for my tractor. Kubota L3130
Front : 27 x 10.5 - 15
Rear : 44 x 18 x R20
Thanks a bunch
   / Kubota L3130 : Can someone confirm I have proper sized turf tires? #2
Kubota L3130 Tires
2WD Ag front:6.0-16
4WD Ag front:7.2-16
Ag rear:12.4-24
Jeff9366 : Thanks for the info. I have the turf tires not the ags
FYI : The manual has a list of tires but they don't show which ones (front vs back) can be paired together for proper ratios
   / Kubota L3130 : Can someone confirm I have proper sized turf tires? #5
If there is more than one set of the same style tire listed the larger diameter fronts get paired with the larger diameter rears.
Sorry, I'm not clear what you mean. This is the only list I can find. I looked in the parts manual, workshop manual and owners manual. I also spent a really long time googling
   / Kubota L3130 : Can someone confirm I have proper sized turf tires? #7
As it happens, the person that put that chart together was smart enough to list the front tires in the proper order with the appropriate rear tires. The combination you posted as having are the second choice among turf tires for both front and rear tires.
@RickB : Unfortunately mine aren't. My fronts are 6th on the list and my rears are 7th.
   / Kubota L3130 : Can someone confirm I have proper sized turf tires? #9
So much for my counting skills. Is there any other tire data in the op manual? Usually the combinations are listed.
I couldn't find anything. I never expected this would be so hard. If I don't hear anything here I'll call the dealer tomorrow and report back.
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
Polecat Swift 206R 20ft Towable Boom Lift (A50322)
Polecat Swift 206R...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A52748)
Kubota SVL65-2...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
Unused 2025 CFG H15 Mini Excavator (A50322)
Unused 2025 CFG...
