Kubota L3010 vs. JD 4300 vs. NH TC33D
   / Kubota L3010 vs. JD 4300 vs. NH TC33D #1
Anonymous Poster
Epic Contributor
I have been looking at the Kubota L3010, New Holland TC33D and John Deer 4300 all with Hydrostatic transmission (HST) and R4 tires. From the specification sheets it was not easy to tell the real difference between them. A couple of the dealers offered to bring them out to my place for me to try. I talked the third one into it and arranged to have them out all at the same time. This is easer said than done but I did get them to overlap by a couple of hours. I lined them all up and took a few digital pictures. I will post them if people would like to see them and the web master will permit the files. This is already a long post but I hope it will be useful.
I have 14 acres total; 8 acres that was old farm land (now weeds) that I will be turning into pasture and 2 acres that will be cleared of brush and made into lawn/pasture. I have planted about 100 trees and a hedge around the property that I will need to maintain. The ability to get under and around the trees has led me to pick these mid size compacts. If I was just working the pasture I would probably look harder at the top size in this series.
I have seen many times on this forum that the dealer can make all of the difference. All of my dealers in Tucson have been extraordinarily helpful. This has taken the dealer factor out of the equation. I also do not come into my evaluation with any brand preference.
I had each dealer bring out a different 5' wide 3pt implement; box scraper, disk and a rotary tiller. I picked these because I was after implements that would take the most power. Aside from front loader work, pulling a box scraper digging in heavy and loading up with dirt was the biggest strain on each. I ran the same box scraper and disk on each tractor. I also used the implements in the same area and soil conditions.
All of the tractors performed the tasks admirably. All power claims seemed to be true. They all stalled or bogged down about the same. I was expecting them to over heat but with temperatures of 105, 106 and 108 Deg F (no, "it is a dry heat" is bull, that is hot!) over my three test days there was no sign of trouble from heat.
Kubota L3010 with LA481 Loader: New unit 3 hours on meter.
Negatives; I asked the sales man to demonstrate the removal of the loader. Four pins must be removed and a support bar on each side dropped down. Problem was it would not come off. A bolt holding the frame on the loader interfered with the tractor frame. The loader is apparently assembled at each dealer. They send a bag of bolts (with lots left over at the end) and the service people take it from there. I went back to the dealer a couple days later after they replaced the bolt that was interfering. It unfortunately took a half hour to have two salesmen demonstrate the "easy" removal of the FEL. They say it should be quick after a little practice. One of the hydraulic connectors is hard to grip since it is very close the frame. Can anybody comment on taking the Kubota FEL on and off on a regular bases? Other than the engine running, none of the electrical worked. Turns out it had been on display at the fair and all of the fuses were removed. Very disappointing since I could not check the work lights. No sign of over heating but I could not watch the temperature gauge. I must give the dealer a break on the electrical because he did not have time to check out the tractor before he brought it out. He only had about two hours notice before I arranged for a demo and he dropped the unit off. The engine compartment side panels are metal but to replace them was difficult, they had to be placed in just the right position to get them to latch, especially the front panel, which also has an electrical connector to fuss with when removing it. My biggest problem was the accelerator pedal. I could not find a comfortable position for reverse. The body work gets in the way when I attempt to use my heel. The cruise control lever is clumsy, but the pedal is smooth so I may not need to use it as much.
Positives; Although the specs do not confirm it, the speed in range 2 seemed much faster than the competitors and it still had plenty of power to drive in and pull out a full bucket.
It is quiet and relatively vibration free. The forward throttle is very smooth and comfortable. This unit looks more like a tractor than the competitors. This comes from larger diameter front and rear tires and a longer front hood. Very quick FEL movement and dual motion.
John Deere 4300 with 420 loader: New unit with 3 hours.
Negatives; I again asked the salesman to remove and replace the loader. During the process he had to lift the front wheel of the tractor with the bucket. This revealed a large hydraulic leak on a rigid line on the bucket frame. He broke out his tool kit and fixed it on the spot but it is very bothersome that a fitting from the factory was not tight. The cruise control worked fine driving on smooth dirt but when disking it would eventually allow the tractor to stop. When asked about this later he said they just changed the pedal configuration at the factory and the magnet on the cruise control would not hold in bumpy conditions. Not encouraging that the factory did not test the modification in field conditions. They are changing the pedals to reduce the force needed to operate them, the problem is I still had a sore knee after operating this tractor 2 hours and that was with the new pedals. The vibration and noise on this tractor is the worst of the three. I ran the New Holland and JD next to each other, moved from seat to seat and all I could hear is the rattling of the JD, even from the NH seat. Only single movement on FEL. Very long flexible rear PTO control, very hard to make fine adjustments. Near the rear PTO up/down lever is the PTO engage lever that is easy to grab by mistake. Hydraulic lines for steering are protected from the front but exposed from the rear, if backing up over brush they could get snagged. Has anybody torn their hydraulic steering lines?
Positives; The FEL goes on and off very easy. It truly does remove from a latch that can be reached from the drivers seat. Very good V shaped guides when pulling up to it to reattach. Starts with turn of key (No PTO engaged) no need to pull out of gear or push in clutch. With PTO engaged the tractor stops if you get out of the seat.
New Holland TC33D No FEL (the loader the dealer was going to attach for the demo did not arrive, expect to put on a Great Bend 240); Used tractor with 153 hours.
Negatives; The specs say it is the same speed in reverse as forward but it only crawled in reverse. The dealer said this could be adjusted. Has anybody changed the maximum reverse speed or is this not really possible? The PTO speed indicator is a light on the dash; in direct sunlight with a little dust on the display the lights are very hard to read. Head light illumination is non-uniform, but good peripheral coverage. Without the FEL it looks like an overgrown lawn mower. Fenders do not cover much of the tires. I assume if I spin the tires in mud I will sling mud everywhere. Must put shift lever in neural before starting. The dealer finally got there loaders in and I looked at one mounted. I did get to remove it part way without any problems but could not really put it through its passes. It was on a new tractor ready for a customer to pick up and I did not want to scratch it up. The movement up and down was slow compared to the Kubota.
Positives; Very quiet smooth ride, down right peaceful after running the JD. Very nice air piston seat, soft up and down and it felt firm side to side. The 20 degree rotation of the seat did help remove some of the strain on my neck when watching the rear implements. Ridged rear PTO lever in comfortable position for my hand and it had good markings plus a height stop. Very good access by lifting hood. Easy to pull radiator screen, filter and battery. Pulled a bigger load in drag box before stalling. Easiest of the three for implement changes. It had the deluxe PTO link but what made it easy was the full float position that let the links move up and down by hand.
The JD is out of the competition but after all of this evaluation I am still having trouble deciding between the Kubota and the NH. Any contradictions or comments on my observations would be appreciated.
   / Kubota L3010 vs. JD 4300 vs. NH TC33D #2
Schooner,
You seem to be having a little fun doing your research! /w3tcompact/icons/smile.gif I wish I had been able to compare units side by side when I bought. I don't have any experience/knowledge of the Kubotas (aren't any dealers in my area) but did compare the JD and NH units. Generally I would agree with your comments. I ended up buying a NH unit but getting a unit bigger than I originally intended (the TC40D instead of the TC33D).
In regards to your comment about the fenders on the NH, I've never seen any fender on any brand that kept mud from flying when the wheels spin in mud. Fenders always seemed to be for safety sake to keep hands from hitting the wheel and keep most mud from the operator. Yes, I agree the NH look is a little like a lawn mower but having gotten used to it I really like the visibility of the front. I get on a "normal" looking tractor and have a lot more problem seeing what is directly in front of me. This is nice when using the FEL and when rotary mowing in the tall grass. Those hidden branches, limbs, toys, etc lying in the grass are nice to avoid.
Never seen or heard of the problem with the forward/reverse speeds not being equal. The dealer should fix that on the unit they have whether you get it or not.
Have fun looking and thinking...
DaveV
DaveV
Thanks for the info on forward and reverse. I drove a couple of TC33D units on the dealer lot and all seem to have much slower reverse speed. Their senior mechanic says he can adjust the reverse speed. The dealer is waiting on more loaders but when they come in they are going to install one and adjust the reverse speed on the tractor. If they get the reverse speed equal to forward then they are going to bring the unit out to my property for another test drive, mostly for a good test of the FEL. While I am waiting I have been thinking about demoing a TC40D. The TC40D is only a little bit larger than the Kubota3010 and the Kubota is still a strong contender. It looks quite a bid bigger on the lot but may fit into most of my tight spaces. The weight may also eliminate using it for finish mowing, but I expect very little of this and maybe it can be done with a cheap Sears type unit.
   / Kubota L3010 vs. JD 4300 vs. NH TC33D #4
Schooner,
If you get a chance, find out what they do to speed up the reverse or even them out. You discovered a good point, for low and mid range can be a little slow when backing up. I have 138 hrs on my TC33D and have never regretted my decision between the three.
On another topic, I just installed a LEON 500 loader on mine and it is almost to fast and very powerful.
Re: Slow Reverse
The New Holland specs show that the reverse speed for at TC33D is slower than forward...Range I 3.9F/2.92R MPH, Range II 8.09F/6.07R MPH, Range III 15.59F/11.69R MPH. The adjustment is under the hydro pedal. The bolt which acts as a stop for the pedal travel is the adjustment. Screw the bolt into the machine for more pedal travel and more speed. The head is 13mm. Instead of just telling me to do this, my dealer sent out a mechanic to perform the adjustment no-charge to me. This change made a big difference in my machine's performance. As delivered, a sudden stomp on reverse in range III didn't cause any perceptable load on the engine, nor any reverse speed near the spec. After the adjustment, a stomp on the pedal in range III delivers the expected loss in engine RPM as the machine accelerates. I haven't timed the machine over a measured distance, but my perception is that the machine meets spec on reverse speed.
MarkK
Marty
The dealer adjusted the stop on a new unit and I could not perceive much difference now in forward or reverse. I tried adjusting the screw on the last demo unit I had and there was no change. I now think the pedal did not have full travel in the slot in the floor or there was something wrong with the linkage. They are bringing a unit out to my property tomorrow to test the Great Bend FEL.
I demoed the Great Bend 240 loader at my place today on a used TC33. The loader performed well (about the same as the JD 420 loader on a JD 4300) and I will be purchasing a new TC33D on Monday. The dealer is waiting on a heavy-duty bucket to come in so I am with out the loader for a couple of weeks on my new machine. As a side note I cannot imagine running a loader on the standard trany TC33 (Gear shift and clutch with no synch reverse). It was painstakingly slow and complex to operate compared to the easy in and out operation of the HST.
In the end I chose the TC33D over the Kubota because the NH packed more punch into a 5' wide machine. I have some tight areas the slightly smaller machine with 5' wide implements will fit much easier. The Kubota is a much bigger machine with a R4 rear tire contact width of 67". This meant I had to jump to 6' implements (tiller and grademaster road grader) to avoid leaving rear tire marks. The TC33D has plenty of power so now if I want to run a 5' or 6' mower, box scraper, disk, etc. I have a choice.
Thanks all for your comments.
   / Kubota L3010 vs. JD 4300 vs. NH TC33D #8
Excellent choice! Just one question,any particular reason you went with great bend loader instead of the 7308 NH?
Arkie
Arkie,
More power; less cost. To start with the spec sheets say 800 lb lift for 7308NH vs. 1120 lb for 240GB. Almost all the specs are better on the GB. I know spec sheets can be deceiving (which is why I tested each tractor) and I did not run a 7308NH loader against the JD and Kubota but my dealer felt the NH 7308 loader would not stack up.
I am also looking at the TC33D. I live just east of Denver and was wondering what type of price range are you getting your TC33D for. Here they are around $19,500. Without attachments except for the front loader which is included.
Parker 4000 Gravity Wagon (A50774)
Parker 4000...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
1994 Toyota 6000lbs 2 Stage Forklift (A52748)
1994 Toyota...
2017 Ford F-250 Enclosed Knapheide KUV Service Truck (A50323)
2017 Ford F-250...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
