Kubota L2900 Transimssion Leak
   / Kubota L2900 Transimssion Leak #1
Anonymous Poster
Epic Contributor
I have a 1994 L2900 GST with 1025 hours. It has developed a serious hydraulic fluid leak. The leak is a steady stream the size of a toothpick. It comes out of the tube in which the front drive shaft is located. It is located between the two drain plugs in the engine oil pan. It would seem to me that the fluid is leaking out of the transmission and is filling the clutch housing until it runs down the drive shaft tube and leaks out of the first joint in the tube. Has anyone seen this problem? Is it a seal? Should the clutch be replaced due to getting soaked with oil (if it is)? If I decide to do the repairs myself, how do I get a shop manual?
   / Kubota L2900 Transimssion Leak #2
Carvers might beable to help you w/the manual.
Visit your dealer and chat w/the tech,and maybe he could give you an insight what your facing.
   / Kubota L2900 Transimssion Leak #3
Grant, we generally see this happen most often in the winter when using the loader for snow removal. The seals that seal the clutch housing from the transmission tend to work there way out. Kubota has a spacer kit available to prevent this from happening. I've seen it both ways (depending on what the customer wanted) Split the tractor, replace the clutch disc
and replace the seals, or push the seals back in with the spacer kit and spray brake clean through the clutch housing drain hole while the tractor is running to clean out some of the oil and hope for the best. Believe it or not the latter seems to work out in most cases. I'll try to remember to get the part number for the spacer kit for you tommorow.
Kubmech:
Please give me more info on the spacer kit. What is it? How is it installed? What are the risks?
Thanks
   / Kubota L2900 Transimssion Leak #5
The part # for the kit is TA040-98001. It comes with an instruction sheet for installation. Basically what it is, is a tube with an o-ring on both ends. I'll try to explain what to do:
Loosen the clamps on the front drive shaft tube and slide the two halves of the tube together to gain access to the front drive shaft. You will see two splined couplers one for the front and one for the back of the shaft. There's a roll pin in each coupler. Rotate the shaft (you will have to lift the front axle off the ground) so you can drive the roll pins out without hitting an obstruction. Once the pins are out slide the couplers away from the splined shaft in the trans and front axle and the front drive shaft can be removed (the couplers may be a little stubborn so don't be afraid to "persuade" them a little). Once the front driveshaft is removed install the spacer on the shaft coming out of the clutch housing and slide it towards the back of the machine. At this point the spacer will be butted against the seals that have backed out. Re-install one of the couplers on the spline and gently tap the coupler against the spacer to re-seat the seals. when the roll pin hole lines up with the end of the shaft (maybe just a hair past) you know the seals are seated. Remove the coupler and the spacer. Now make sure everything is in neutral, set the parking brake, and latch the clutch pedal in the disengaged position and start the tractor. Throw some saftey glasses on (goggles are better)
Remove the weep plug from the botom of the clutch housing and place a drain pan under where the shaft splines come out. And go nuts with a couple of cans of brake clean with the spray tube installed in the nozzle. This should do a pretty could job of getting most of the oil out of the housing and off of the clutch disc. Now if you have an air compressor blow the housing out (not really that necessary as brake clean evaporates quite well, just speeds up the process for leak checking). Let it run for a bit to make sure the leak has been re-sealed. Now install one of the o-rings from the kit on the rear shaft and slide the spacer back on. Once the spacer is seated against the seals install the other o-ring and re-install the drive shaft with the couplers. Basically the rear coupler pushes against the o-rings and the spacer and prevents the seals from working there way out again. Put everything back together in reverse order and drive away. If this "technique" does'nt work your really not losing anything as you would have to tear it down and replace the same parts anyway. So it's worth a shot.........Oh, keep in mind when putting the roll pins back in, they fit between the shaft ends, that's what keeps the shaft from falling out.
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
NEW Wolverine Skid Steer Bucket Root Rake Attachment 34'' (A53002)
NEW Wolverine Skid...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A51692)
2007 Ford E-450...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
2022 JOHN DEERE 6120M LOT NUMBER 192 (A53084)
2022 JOHN DEERE...
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A53426)
2007 POWERSCREEN...
