Kubota L2900 hyd question
   / Kubota L2900 hyd question #1
fireemann
Bronze Member
southeastern Ohio
I am wanting to tie into the hydraulics on my loader and install a 3rd function. I have found 12volt solenoid valves on surplus center.
Will these work?
if i remember right my system is like 8 gpm and 2200 psi. I know it has power beyond.
If the open center one wont work where can i find one that does. I thought about the selector valve and not sure thats the way I want to go.
Cool..Thanks. I have been looking and trying to find one and havent been able to find a solenoid valve that listed power beyond. This was the closest I could come up with.
   / Kubota L2900 hyd question #6
Solenoids valve sub plates don't use the term PB, because the IN and OUT ports can handle the high pressure, some up to 5000 psi.
that explains it.. its all starting to make some sence. Thanks for the expertise and insight.
2022 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
100 GAL FUEL TANK (A50854)
100 GAL FUEL TANK...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
TTS5-10680 Rubber Tire Asphalt Roller (A49461)
TTS5-10680 Rubber...
