Kubota l2850 gear pitch
/ Kubota l2850 gear pitch #1
jjeff
Super Member
MI
kubota l2850, kubota l4150
Hi,
I was replacing the front seals on my l2850 and I replaced the small lower bevel gear also. Unfortunately when I put everything back together and tighten the bolts the hub assembly doesent spin it binds up.. Looking at the parts manual I have there's two different part numbers both 12 tooth for the small lower bevel gear.wondering if they are different pitch? Does Kubota label the pitch on the bevel gears I noticed the number 27 on one and 22 on the new one? Problem is I'm in the middle of nowhere and I'm trying to figure this out in the sticks......
Thanks,
Jeff
John Deere 6 Row Do All (A60462)
John Deere 6 Row...
(15) Polyethylene Road Bed Protection Pads (A60463)
(15) Polyethylene...
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
2017 Rogator RG1300B Dry Fertilizer Applicator (A61307)
2017 Rogator...
Sdlanch SDLGC80 (A60463)
Sdlanch SDLGC80...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
