Kubota L285 with low oil pressure
   / Kubota L285 with low oil pressure #1
cedar123
Winnipeg,Manitoba
Kubota L285
I have a kubota L285 with low oil pressure , removed sender, installed gauge have 7 PSI cold at 1000 rpm, 15 PSI cold at full speed. So far I have gone to a thicker grade oil 15/40, slight increase in pressure, removed pan checked sump screen, plastigaged the con rod bearings they are within tolerence, .003 clearance. My next step is to check oil pump clearances, got to get more tools first. I also heard that the cam shaft plug falls out of these things. any other ideas?
   / Kubota L285 with low oil pressure #2
Welcome to TBN. :)
   / Kubota L285 with low oil pressure #3
Sounds like your well on your way to a solution to the problem!
:welcome: to TBN! :thumbsup:
Happy :tractor: ing!
   / Kubota L285 with low oil pressure #5
WELCOME to TBN :)
I moved your thread to the Kubota Owning/Operating Forum.
   / Kubota L285 with low oil pressure #6
One or both of the cam plugs fell out it sounds like (I would bet money on it!). You're going to have to remove the timing cover and remove the cam to replace them. Fix it asap before you hurt the cam bore which doesn't use bearings and would ruin the block. I would weld the replacements in place.
   / Kubota L285 with low oil pressure #7
If the cam plugs are still in place, go back to the oil pump and be sure that the relief valve has not gotten stuck in the open position.
Thanks for your replies, it turned out to be the front plug in the cam shaft after all. But after the dust has settled I now know the condition of my engine. With every thing back together the oil pressure is now 80 PSI with 10w30 oil in it.
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
2017 Ford F-250 Ext. Cab Pickup Truck (A50323)
2017 Ford F-250...
PENDING SELLER CONFIRMATIONS (A52576)
PENDING SELLER...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
20' Sea Container (A50774)
20' Sea Container...
