Kubota L2800
   / Kubota L2800 #2
It’d probably lift it off the ground but if you’re stacking 800-1000lb round bails up high it could induce instability on a 2600lb 63in wheelbase machine. Would definitely want to have the tires loaded and ballast on the 3pt.
   / Kubota L2800 #3
Based on my experience with an L3200, I don't think it will lift a round bale safely, and I also suspect you're guessing wrong. Get the numbers right and then compare directly to the loader specs to know for sure.
   / Kubota L2800 #4
As already said rear tires loaded also R4 tires little better for higher lift.
   / Kubota L2800 #5
I'd go bigger for large round bales. You could move them with a rear bale spear like I used to on my L3710. I tried lifting a large bale with bucket forks once and it wouldn't do it. I'm sure it would have with a bale spear loader attachment. That said, the loader for a L2800 is considerably smaller.
TractorData.com Kubota L371 tractor attachments information
Loader: Loader type: Kubota LA681: Height (to pin): 102.4 inches [260 cm] Clearance, dumped bucket: 80.3 inches [203 cm] Dump reach: 23.4 inches [59 cm] Dump angle: 40: Reach at ground: 66.5 inches [168 cm] Rollback angle: 23: Breakout force (lift): 2557 lbs [1159 kg] Lift to full height (at pin): 1499 lbs [679 kg] Bucket width: 60 inches [152 cm] 66 inches [167 cm]
TractorData.com Kubota L28 tractor attachments information
Kubota LA463: Height (to pin): 95.3 inches [242 cm] Clearance, dumped bucket: 76.2 inches [193 cm] Dump reach: 22.2 inches [56 cm] Dump angle: 40: Reach at ground: 64.5 inches [163 cm] Rollback angle: 31: Breakout force (at 500mm): 1,858 lbs [842 kg] Lift to full height (at pin): 1,142 lbs [518 kg] Lift to full height (at 500mm): 853 lbs [386 kg]
I'm interested to see if anybody uses a tractor that small though.
Kevin
2020 Peterbilt 389 Tri-Axle Sleeper Cab Truck Tractor (A49461)
2020 Peterbilt 389...
2013 KOMATSU PC490LC-10 EXCAVATOR (A51242)
2013 KOMATSU...
2015 CATERPILLAR 289D SKID STEER (A51242)
2015 CATERPILLAR...
2013 HINO 388 (A50854)
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A51219)
2016 WESTERN STAR...
