Kubota L275 hydraulics
   / Kubota L275 hydraulics #1
edlomax
Replaced pump - still no hydraulic for PS, lift, or Frt end loader. All fluid is returning to trans and flows out if plug is opened. Is this a relief valve problem or a priority flow valve problem - these parts are very expensive and don't want to replace both if not needed. Thanks
Well today I removed and cleaned the priority and relief valves, changed the hydraulic fluid and still no hydraulics. pulled relief valve and got only a drip of fluid - same at power steering line and fe loader. Removed hydraulic filter and got sucking sound and little fluid in filter. There is no filter at return line. Anyone have any ideas? Thank you.
   / Kubota L275 hydraulics #3
Is your main filter in the transmision clean? Also follow the lines and make sure none are crimped off.
Have not found a main filter in transmission - will check parts book again. Thanks.
   / Kubota L275 hydraulics #5
Here is a pic out of my book. It is on the left side of the tractor right at the bottom of the trans case. #19
   / Kubota L275 hydraulics #6
Hydraulics quit after fluid becomes hot. Changed fluid & filter. Added shims to relief valve springs that helped somewhat. Cannot find new relief valve. Kubota dealer inticates no longer available. How do I fix the relief valve? Is there another sorce for these? Is there another fix?
BP
City of Buckhannon -Onan 50 Set Stand By Generator (A52384)
City of Buckhannon...
(INOP) KOMATSU PC200LC-8 EXCAVATOR (A51246)
(INOP) KOMATSU...
JOHN DEERE 1725 CCS LOT NUMBER 29 (A53084)
JOHN DEERE 1725...
2009 Jordair Marines-320-DH Trailer Mounted Air Compressor (A51691)
2009 Jordair...
2015 MAC FLATBED 48FT TRAILER (A52141)
2015 MAC FLATBED...
Landoll Hauloll (A53472)
Landoll Hauloll...
