Oil & Fuel kubota l260 no oil pressure
   / kubota l260 no oil pressure #1
fred68
kubota l260
I have a l260 kubota that has no oil pressure,my question is ,when I took the inspection plate off the crankcase,there is no oil pickup tube. how does the oil get to the oil pump?
   / kubota l260 no oil pressure #2
Hey Fred - welcome to TBN -
The L260 is not a widely known model - but there are some members who may have the knowledge you're looking for. I noticed this thread that has a picture of the oil pressure sender. Instead of the light, did you try a pressure gauge? My Kubotas don't have inspection plates that would give a view of the crankcase or oil pickup - on some engines the pump is mounted in the middle area, mostly submerged, with a flat round inlet about the size of a catfood can. The only way I've ever seen one without taking off oil pan (big job on a tractor) is with the oil drained, looking through the drain hole. Maybe you can send PM's to the other posters. Good luck. Dick B
Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
Godwin CD150M 6in...
New Long Forks (A53002)
New Long Forks...
NEW Woods 6ft Finish Mower (A53472)
NEW Woods 6ft...
UNUSED GREAT BEAR 1.5CY SELF DUMPING HOPPER (A51248)
UNUSED GREAT BEAR...
Miller Wildcat 350-D Welder (A51691)
Miller Wildcat...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
