Oil & Fuel kubota l260 no oil pressure
   / kubota l260 no oil pressure #1
fred68
kubota l260
I have a l260 kubota that has no oil pressure,my question is ,when I took the inspection plate off the crankcase,there is no oil pickup tube. how does the oil get to the oil pump?
   / kubota l260 no oil pressure #2
Hey Fred - welcome to TBN -
The L260 is not a widely known model - but there are some members who may have the knowledge you're looking for. I noticed this thread that has a picture of the oil pressure sender. Instead of the light, did you try a pressure gauge? My Kubotas don't have inspection plates that would give a view of the crankcase or oil pickup - on some engines the pump is mounted in the middle area, mostly submerged, with a flat round inlet about the size of a catfood can. The only way I've ever seen one without taking off oil pan (big job on a tractor) is with the oil drained, looking through the drain hole. Maybe you can send PM's to the other posters. Good luck. Dick B
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
2022 John Deere X9 1100 Combine, (A53342)
2022 John Deere X9...
FRONTIER MG20F LOT NUMBER 83 (A53084)
FRONTIER MG20F LOT...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
