kubota L2550
   / kubota L2550 #1
fish4824
dalton ma
kubota L2550
my low oil lite went out so i changed my oil and now it wont start any ideas
   / kubota L2550 #2
More info would help... Does the engine crank but not catch, or will it not crank? Fuel good? Glow the plugs OK?
Mike
   / kubota L2550
yes it cranks over the glow plugs are ok but the oil pressure lamp goes out when i crank it over
   / kubota L2550 #4
If you're cranking long enough the oil pressure light may go out because the pump is producing enough pressure. Did it start and run OK before the oil change? Is that the only thing you did? I'd check the fuel filter to ensure that it's clear.
Mike
   / kubota L2550
i was running then it stalled when i cranked it over again the low oil lamp did not lite so went and got new oil and filter and changed it today now when i crank it over the lamp goes off i dont know what else to try thanks for taking the time to try to fix my problem
   / kubota L2550 #6
When it stalled, were you doing something where it was reasonable to stall - or did the motor just stop? If all of the basics are covered - mostly fuel, then your friendly neighborhood Kubota shop may be the next stop. Make sure that the emergency stop widget is not pulled/pushed (I've never actually used mine so I don't remember) out of position.
Mike
2016 HINO 268 26FT BOX TRUCK (A51222)
2016 HINO 268 26FT...
2018 Toro Sand Pro Bunker Rake with Edger Broom (A49461)
2018 Toro Sand Pro...
2025 78in Rock Bucket Skid Steer Attachment (A50322)
2025 78in Rock...
2013 FREIGHTLINER CASCADIA (A50854)
2013 FREIGHTLINER...
2024 Isuzu NRR 24ft Box Truck (A50323)
2024 Isuzu NRR...
KUBOTA M7040 TRACTOR (A51406)
KUBOTA M7040...
