Kubota L2501 performance
/ Kubota L2501 performance #11
Goreef I have no issues shifting from forward to reverse on L2501dt as long as tractor is stopped there should be no grinding. When shifting into any gear from neutral give the gears about 4 seconds to stop spinning or you will get grinding
I have a L3901DT and as long as you have the clutch in you can change the direction without stopping, it tells you this in the manual. But like OC3 said, to shift gears you need to be stopped and wait a couple of seconds before changing gears.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1992 Norris Long Basket Trailer (A55973)
1992 Norris Long...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2018 John Deere 5075E (A60462)
2018 John Deere...
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
207281 (A52708)
207281 (A52708)
