Kubota L245H help with ignition wiring
   / Kubota L245H help with ignition wiring #1
Forest72
Heath, tx
Kubota rtv900 xt
Hello to the experts. Need help with finding new replacement connections that connect wires from ignition to wires going to starter for this L245H, please see pics. These white connection pieces are crumbling... also a wiring diagram would be very helpful if avail. Thanks for the help.
   / Kubota L245H help with ignition wiring #2
You could stop by your local NAPA dealer and see what kind of connectors are available. They won't be like the originals but it you can get a male and female to match and watch which wire goes where you should be in business.
   / Kubota L245H help with ignition wiring #3
Kubotabooks.com has an operators manual complete with wiring diagram.
The deteriorating connectors exist for assembly purposes and can be eliminated by soldering the wires together one at a time.
Index of Kubotabooks/Tractor Owners Manuals/
Dave M7040
   / Kubota L245H help with ignition wiring #4
I'd generally recomend Weatherpack or Metripack connectors. Weatherproof & what is used in most american cars these days. Deutch connectors are better, but more expensive & require less common tools.
Amphenol-Deutsch vs weatherpack plugs when wiring up a truck - Pirate4x4.Com : 4x4 and Off-Road Forum has good info on connectors. I referenced it a lot before my L4060HSTC wiring project. https://www.tractorbynet.com/forums/customization/376458-let-there-light-l4060-light.html
Soldering may work, but I always prefer easily removable options as close to OEM as possible for maintnance & repair.
Thanks guys. I ended up hard wiring and it fired right up. Now the back right wheel is locked and the brake isn't on. ANy idea?
SKLP Pipe Banding Machine (A57149)
SKLP Pipe Banding...
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57453)
New/Unused 20ft...
2016 VOLVO VNL780 SLEEPER (A59575)
2016 VOLVO VNL780...
Kenco 3 Row Plastic Layer (A57148)
Kenco 3 Row...
Ford F550 Dump Truck w/ Plow (A55272)
Ford F550 Dump...
2025 Swict 72in Bucket Skid Steer Attachment (A56857)
2025 Swict 72in...
