Kubota L245H--Head Gasket Woes
   / Kubota L245H--Head Gasket Woes #1
Mike Madison
MF-35, Ferguson to-30, Kubota 245H, Kubota L3450, Kubota MX4700
Hello Good People. My Kubota L245H cultivating tractor, over a period of a week, became hard to start, died at idle, and significantly lost power. I thought it was a fuel problem, so I drained and cleaned the fuel tank (full of dirt) and fuel lines and put a new fuel filter. No better. The intern (smart girl) noticed a fluid leak (coolant) coming from the junction of the block and the head. Before pulling the head I drained the coolant by removing lower radiator hose. Hardly any coolant came out. When I pulled the head it appeared to be still full of coolant, mixed with oil. The head gasket had been installed by a previous owner with a lot of rubbery goop on both sides and white deposits where it had been leaking. Cylinders are smooth (no ridge), but piston tops have significant carbon deposits (up to 1/4 inch thick) as do valves. The tractor did not overheat and the head is flat. Should I just reassemble with a new head gasket (no goop), or I should I do something more, like an in-frame rebuild? Tractor doesn't smoke, but even before this event it seemed to lack power. I did not do a compression test. This is a 40 year old tractor that was worked hard in the strawberry fields before I got it. Hours unknown, maintenance history unknown. Thanks for your wise advice.
   / Kubota L245H--Head Gasket Woes #2
Why has it so much build up of carbon? Never used hard enough? It it's not much work I would pulled the pistons, clean and maybe hone and fit new rings.
   / Kubota L245H--Head Gasket Woes #3
mike i would use star bright in the fuel after you clean it up, dont think pistons need removing just clean up and install new gasket . Set valves cold at 007 to 009
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
Ryobi Weedeater (A51573)
Ryobi Weedeater...
KUBOTA ZD1211 (A53084)
2015 CATERPILLAR 262D SKID STEER (A51246)
2015 CATERPILLAR...
BROWN BDH-600 LOT NUMBER 174 (A53084)
BROWN BDH-600 LOT...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
