Kubota L245DT Hydrolic lift/ three point problem
   / Kubota L245DT Hydrolic lift/ three point problem #1
Jjpbe
Yanmar 1510D / Kubota L245/ Toro 223D
Hi,
I am owning a Kubota L245DT which works well. I only have a problem with the hydrolic lift/ three point . It’s not lifting very high. It should lift much higher. What could be the problem? I have checked the hydrolic/transmission oil but that seems ok. Any ideas?
many thanks.
jjp
   / Kubota L245DT Hydrolic lift/ three point problem #3
Do you have a stop on the control lever? Have you moved it? Many tractors have an adjustable upper and/or lower limit point on the control. You could start by checking for that.
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2014 PETERBILT 579 SLEEPER (A52576)
2014 PETERBILT 579...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2018 FREIGHTLINER...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2023 JOHN DEERE 7R210 LOT NUMBER 95 (A53084)
2023 JOHN DEERE...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
