Kubota L2350DT water pump question
   / Kubota L2350DT water pump question #1
toyotadriver
Kansas City, KS
Kubota L2350DT
First post here. Been reading here for awhile but finally bought my first tractor. I bought a 1997 Kubota L2350DT 4x4 with a FEL. It has about 800 hours on it.
I'm planning to go through it end to end to completely service it. Once it's completely serviced, I plan to repair the sheet metal where it needs it and then re-paint it.
My question is, how long should the water pump be good for? I like to do preventative parts replacement so that my equipment doesn't break down at the wrong time. So, with these hours and this age, should I be planning to replace the water pump?
I will be replacing the various hoses and belt and completely servicing all the fluids. I'm trying to decide if I should replace the water pump while I'm at it.
Thanks for the help!!
   / Kubota L2350DT water pump question #2
Why repllace something that is working fine? Some of them well last longer then the tractor. No can say when a water pump is going to go bad.
   / Kubota L2350DT water pump question #3
The pump that is in there can also be a better pump than the replacement... Leave good parts alone, I know some kubota engines with well over 5000 hours still fine with the original water pump... KennyV
Thanks for the info. I'll probably leave it in there then.
   / Kubota L2350DT water pump question #5
Check the bearing play on the pump. If it is tight, leave it be. They can run 1000's of hrs and I have had some run less than a 100.
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
NEW Woods Reverse Rotation 5ft Tiller (A52748)
NEW Woods Reverse...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
2010 MACK PINNACLE (A52472)
2010 MACK PINNACLE...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A52577)
2018 KENWORTH T680...
