Kubota L2250 wont steer...
   / Kubota L2250 wont steer... #1
rprewett
Bithlo
8N, TO35 Massey, Kubota
The bevel gears need to be replaced, so I tried, the bevel gear case will not come off [break free from the main housing]. I've tried for several days to find a service manual for this tractor ##$@%%# I've never had so much trouble finding a manual, from go-carts to Over-the-Road tractors. Does anyone have one. I took the steering shaft/column off [three hours wasted], removed bolts from case and and and nothing. Please help. Hate to replace tractor, so I'll have a manual.
   / Kubota L2250 wont steer... #2
It won't steer, or it doesn't have any power steering? It used to be very common for the coupler between the main hyd. pump and the p/s pump to break. If the p/s pump doesn't turn, no power steering. Why do you think the bevel gears need to be replaced to correct a steering problem? Why did you remove the steering shaft/column if the bevel gears need to be replaced? Have you tried calling a Kubota dealer to get a repair manual? I have almost every manual for Kubota's, up to 2000, so they aren't that tough to get.
Brian
2014 John Deere 644K Articulated Wheel Loader (A50322)
2014 John Deere...
KJ 11'x19' Single Steel Carport (A50121)
KJ 11'x19' Single...
2021 Dodge Ram 2500 Promaster (A50120)
2021 Dodge Ram...
New Swict 66" Skidloader Bucket (A50774)
New Swict 66"...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
2005 MACK Roll-Off TK (A50323)
2005 MACK Roll-Off...
