Kubota L2250 Power Steering
   / Kubota L2250 Power Steering #1
Bill_X
Kubota L2250
Due to my overly rambunctious use of this tractor, which handles the abuse pretty well, I popped the hose between the transmission fluid filter and the pipe that goes back to the rear of the tractor. I had to remove the pipe to get the hose back on and in doing so lost the majority of the transmission fluid. I replaced the fluid, which probably needed it anyway, and now the power steering seems not as responsive as it used to. Does the power steering pump need to be bled, is there some other procedure that needs to happen, or is the pump maybe on the way out. The tractor is an 88, but has only a little over 600 hours on it. Any help would be appreciated.
Thanks
   / Kubota L2250 Power Steering #2
It sounds like there is air in the system, however with use it sould work it's way out of the system.
2011 Mitsubishi Outlander AWD SUV (A51694)
2011 Mitsubishi...
John Deere 2440 Tractor (A52384)
John Deere 2440...
2017 Jeep Wrangler (MPV), VIN # 1C4BJWDG2HL674841 (A51572)
2017 Jeep Wrangler...
City of Buckhannon - 2000 GMC 3500 Service Truck (A52384)
City of Buckhannon...
Mccormick Hammer Mill (A51573)
Mccormick Hammer...
