Due to my overly rambunctious use of this tractor, which handles the abuse pretty well, I popped the hose between the transmission fluid filter and the pipe that goes back to the rear of the tractor. I had to remove the pipe to get the hose back on and in doing so lost the majority of the transmission fluid. I replaced the fluid, which probably needed it anyway, and now the power steering seems not as responsive as it used to. Does the power steering pump need to be bled, is there some other procedure that needs to happen, or is the pump maybe on the way out. The tractor is an 88, but has only a little over 600 hours on it. Any help would be appreciated.
