Kubota L2250 - FULL THROTTLE RUNAWAY
   / Kubota L2250 - FULL THROTTLE RUNAWAY #1
llelectrical
loranger,la
L2250
KUBOTA L2250 , 650 HRS, Starts, OK ,then jumps to full throttle with no key on/off effect). Replaced throttle STOP solenoid but the STOP lever is stuck[ in "full open". HELP!
   / Kubota L2250 - FULL THROTTLE RUNAWAY #2
I think you'll have to pull the injection pump and have it gone over one of the valves is most likely stuck.
   / Kubota L2250 - FULL THROTTLE RUNAWAY #3
If you have a solenoid on/off valve to shut off the engine, it should cut the fuel. If you have a manual fuel cut off make sure that it is connected to the control lever on the ejector pump.
Otherwise, either the metering valve is stuck full open or the governor's not working.
   / Kubota L2250 - FULL THROTTLE RUNAWAY #4
Jerry has the proper terminology had the metering valve stuck once and had the same result as you. I now use Stanadyne in the fuel for all my diesel engines for lubricity I'm sure there are many good products that will serve the purpose as well to help deter pump wear.
   / Kubota L2250 - FULL THROTTLE RUNAWAY #5
The RACK is stuck in the wide open position due to the PLUNGERS sticking..
Nothing you can do, but pull the injection pump.
GOODYEAR SET OF 9.5-24 AG TIRES (NEW) (A53472)
GOODYEAR SET OF...
Electric Concrete Mixer (A51573)
Electric Concrete...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A52377)
2012 Chevrolet...
John Deere 1025R with Loader (A51573)
John Deere 1025R...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51691)
2020 Polaris...
