Kubota L2250 - FULL THROTTLE RUNAWAY
   / Kubota L2250 - FULL THROTTLE RUNAWAY #1
llelectrical
loranger,la
L2250
KUBOTA L2250 , 650 HRS, Starts, OK ,then jumps to full throttle with no key on/off effect). Replaced throttle STOP solenoid but the STOP lever is stuck[ in "full open". HELP!
   / Kubota L2250 - FULL THROTTLE RUNAWAY #2
I think you'll have to pull the injection pump and have it gone over one of the valves is most likely stuck.
   / Kubota L2250 - FULL THROTTLE RUNAWAY #3
If you have a solenoid on/off valve to shut off the engine, it should cut the fuel. If you have a manual fuel cut off make sure that it is connected to the control lever on the ejector pump.
Otherwise, either the metering valve is stuck full open or the governor's not working.
   / Kubota L2250 - FULL THROTTLE RUNAWAY #4
Jerry has the proper terminology had the metering valve stuck once and had the same result as you. I now use Stanadyne in the fuel for all my diesel engines for lubricity I'm sure there are many good products that will serve the purpose as well to help deter pump wear.
   / Kubota L2250 - FULL THROTTLE RUNAWAY #5
The RACK is stuck in the wide open position due to the PLUNGERS sticking..
Nothing you can do, but pull the injection pump.
2016 CHEVROLET SIVERADO 4X4 PICKUP (A52577)
2016 CHEVROLET...
New/Unused 72in Quick Attach Rock Bucket (A51573)
New/Unused 72in...
2003 JOHN DEERE 350D OFF ROAD DUMP (A51246)
2003 JOHN DEERE...
2018 Freightliner M2 106 Cab and Chassis Truck (A51692)
2018 Freightliner...
1272 (A50490)
1272 (A50490)
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
