Kubota L2250 Dies
   / Kubota L2250 Dies #1
IloveJD
Hey Guys, I recently bought a L2250 and it has ran just fine until today , as i was moving some manure the tractor suddenly started to lose power and started to die, so i stopped the tractor and it idled fine for a few seconds and then it died completely, so i tried to started it again it ran for a few seconds and and then it wouldn't start again.:confused: I am going to bleed the system tomorrow. Do you guys have any other suggestions? the tractor has about 2000 hours on it. Thanks and happy new year!
   / Kubota L2250 Dies #2
change the fuel filter and then bleed it-this might fix it-my l2500 did nearly the same thing last year. let us know how you make out
   / Kubota L2250 Dies #3
another thought- are you sure that you are getting fuel to the engine- another member a few weeks back had a similiar prob and ended up blowing lines out and that fixed his prob-apparently sucked something up out of tank and that blocked line-------luck
   / Kubota L2250 Dies
Thanks for the input guys, i will try those things tomorrow and see if that works. I will let yall know.
   / Kubota L2250 Dies #5
My Kubota B7100Hst used to sound just like that just before I checked the bottom of the fuel tank for debris!!:D:D
   / Kubota L2250 Dies #6
I agree, check for trash in the line or tank. Not sure where you are but if your in a cold climate it could be the fuel jelling also.
MarkV
   / Kubota L2250 Dies #7
Once a diesel fires up, in general, there are only two ways it can stop. They are from fuel or air starvation.
Sure there are other expensive ways for a diesel to die, but 90% of the time it's either fuel or air. Of those, it's almost always fuel starvation. I'd replace the filter and, while you're at it, I'd also buy a second filter just in case you have a really contaminated batch of fuel. Buying two filters at time could save you a trip back to the dealer. If there's a water trap, check to make sure it's clean.
If both filters clog up then you should drain and flush your tank and fuel lines. The lines after the filter should be OK as the crud should have been caught in the filter. Unless you're sure the air filter in clean, why not change the air filter at the same time? That takes another potential problem out of the mix. I didn't check where you live but if you live in a cold part of the country and you have summer diesel it could have gelled up. Likely not the problem, but you never know,
   / Kubota L2250 Dies
hey guys I went out this afternoon and blew out the feul lines an bled the system and that fixed the problem, its running perfect now! thanks for the advice
   / Kubota L2250 Dies #9
atta boy---------now go play
2012 Chevrolet Captiva Sport SUV (A50324)
2012 Chevrolet...
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A52748)
2003 International...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
Toro Workman Utility Cart (A51694)
Toro Workman...
