Tires Kubota L2201 tires
   / Kubota L2201 tires #1
dbharness
Memphis, TN
Where can i find tires for a Kubota L2201? I have the rice patty tires now. I want some ag tires that have smaller lugs. Turf tires would work.
Will the wheels from a L245 work?
Can i reverse the rims to get more width out of the wheels i have now?
I have had the L2201 now over a year. The rice patty tires are way to rough. I would really like to find a set of wheels with turf tires. That would allow me to switch them out when i need to mow or blade.
any pointers to where to buy a set would be appreciated.
Will a set of turf tires off a L245 work on the L2201?
   / Kubota L2201 tires #4
Measure your lug pattern and diameter of your tires and go down to your local Kubota dealer and compare the dimensions with the new tractors. When you find what you need just go inside and order them. That's what I did. Worked perfectly.
Eugene
   / Kubota L2201 tires #5
Eugene
A new set will cost between $800 and a $1000 from my local Kubota dealer. Any other ideas.
   / Kubota L2201 tires #7
Sounds about right. Mine were $900.
Eugene
This friday i am going to drive 4 hours to look at these wheels and tires. Does anyone have any idea if the wheels from a B8200 will fit a L2201.
FYI. From what i can determine from my research. The measurements for the B8200 rims(bolt pattern and hub diameter) are exactly the same. BUT, because of the smaller diameter of the turf rims and the offest(3.5") comes very close to interferring with the drive gear housing. I am going keep looking.
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
(9) 2 PLUG VALVES (A52472)
(9) 2 PLUG VALVES...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2015 Chevrolet...
New Valley Pioneer SCL850 Mini Skidloader (A50774)
New Valley Pioneer...
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-250...
KJ (9) 5'x5'6" Wire Mesh (A50121)
KJ (9) 5'x5'6"...
