I have had the L2201 now over a year. The rice patty tires are way to rough. I would really like to find a set of wheels with turf tires. That would allow me to switch them out when i need to mow or blade.
any pointers to where to buy a set would be appreciated.
Will a set of turf tires off a L245 work on the L2201?
Measure your lug pattern and diameter of your tires and go down to your local Kubota dealer and compare the dimensions with the new tractors. When you find what you need just go inside and order them. That's what I did. Worked perfectly.
FYI. From what i can determine from my research. The measurements for the B8200 rims(bolt pattern and hub diameter) are exactly the same. BUT, because of the smaller diameter of the turf rims and the offest(3.5") comes very close to interferring with the drive gear housing. I am going keep looking.
