Kubota L2180-1 and L2184 Snow Plow on Kubota L4610 w/ LA852
   / Kubota L2180-1 and L2184 Snow Plow on Kubota L4610 w/ LA852 #1
OutBurst
Connecticut
John Deere 1026r
So I am trying to determine if the Kubota L2180-1 frame and L2184 snow plow will work on a Kubota L4610 with an LA852 loader. I know the loader arms will have to be removed when using the plow but I don't know if the frame will be to remain on the tractor when the loader arms are back on. I don't want to have to remove the frame each time I switch from loader to plow. Also, will the L2180-1 frame even work on an L4610? I know it'll work on a Grand L30 or Grand L40 - not sure on the Grand L10! For some reason finding a list of attachments and accessories for the L4610 is like finding a gnome in a bikini in a South African conflict diamond mine...
   / Kubota L2180-1 and L2184 Snow Plow on Kubota L4610 w/ LA852 #2
View attachment 451134I doubt it's a direct match. The original brochure lists an L2072-1 front blade for all of the Lxx10 Grand L models except the L4610, for which no front blade was offered. The 4610 had the LA852 loader and a heavier front axle than the other xx10 models, so the attachment subframe kit for the 2072-1 likely would not have fit the 4610. Moreover, the LA853 loader on the Lxx30 models, although equivalent to the LA852, had a different subframe design, and the L2180-1 subframe used with the xx30 models - I'm just guessing here - wouldn't match up either.
If it's any help, here's an attachment list from the Lxx10 series brochure.
Thanks for posting that - I'm finding it annoying the L4610 seems to be an odd-man out when it comes to a lot of Kubota attachments. Have you found this true with your experiences?
   / Kubota L2180-1 and L2184 Snow Plow on Kubota L4610 w/ LA852 #4
Really not; it's been more than adequate for everything we've done with it. It was available with a quick-attach loader setup, although mine only has the conventional pin-on type bucket. There are 4610 owners here that have successfully added grapples, etc. to their tractors... not Kubota branded, but there's such a wealth of other stuff that's never been a concern. On the back, it's standard Cat I fare. I use: 72" tiller, 72" box blade, 84" HD scraper blade, 72" cutter, PHD, spreader and subframe backhoe. At one time had a logging winch also. Only the backhoe is Kubota branded (The 84" blade actually came with a Kioti decal on it. :laughing:).
This tractor is a bit much for a belly mower so I can appreciate why they didn't offer a mid-pto setup for it. I also think it was a first move by Kubota toward the heavy-frame "compacts in name only" tractors that are so popular today, with a strong loader, more hydraulics and heavy-duty front axle. The xx30 and xx40 series were brought out not long after, incorporating refinements along the same lines.
Mine has really delivered outstanding, trouble-free service, by the way.
What I am referring to is things like the LA852 is vastly different from the LA853/854 and I can't find things like draft control or rear remote kits - in addition to plow subframes and such. Maybe I'm splitting hairs but I really hate Kubota's website on stuff like this!
   / Kubota L2180-1 and L2184 Snow Plow on Kubota L4610 w/ LA852 #6
You're right about that website, that's for sure! As for being stranded with a product for which factory accessories are no longer available, that's a reasonable concern, but it's not unique to your tractor or to Kubota. I don't think anyone (even Deere) still sells new dealer installed add-ons for equipment they stopped making more than a dozen years ago. Considering the L10's went out of production in 2002, OEM new add-ons and accessories are no doubt getting a little sparse by now. While there's probably a few such things in a back corner of some dealers stockroom, finding them would be very difficult.
The draft kit and remote kit would have been standard to all of the Lxx10 models, I remember the factory remotes were very pricey at the time, but adding a non-OEM setup is quite affordable, although it wouldn't tuck in next to the seat like the Kub setup.
2024 BRAZOS 53FT ALUMINUM STEP DECK (A52472)
2024 BRAZOS 53FT...
2008 DOOSAN G80 GENERATOR (A52472)
2008 DOOSAN G80...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A52748)
Adams Load Out...
2018 Sakai SW990-1 Tandem Vib Roller (A52384)
2018 Sakai SW990-1...
Peterbilt 377 Semi-Truck (A52748)
Peterbilt 377...
