Kubota L185 "R1" Agriculture Tread Tires for rear.
   / Kubota L185 "R1" Agriculture Tread Tires for rear. #1
MikeyG
Alabama
Kubota L185 \"R1\" Agriculture Tread Tires for rear.
First of all thanks to Kuby for the info on the loader hookup. I used and abstract version of your set up and it works great.
My L185 came with 13.6 x 16 Turf Tires. I can not find that size AG Tire. I need a set of AG Tire wheels for this 2WD tractor. Or, I need to know if anyone knows a better way to do this. Wheels are 6 lug with approximately 3" lug to lug.
Thanks, MikeyG
   / Kubota L185 "R1" Agriculture Tread Tires for rear. #2
Re: Kubota L185 \"R1\" Agriculture Tread Tires for rear.
Mikey.......I have a set of original tires & rims off my grey market kubota L1500DT. That model is equivelent to the US L175 model. They're ag tires but very aggressive tread for the rice patties in japan. I took them off and put turfs the same size as you're running on your tractor now. Attached is a picture of my tractor with the turfs on so you can compare the size of my tractor and yours. I can get a picture of the ag tires & wheels tomorrow if you think the tractors are comparable in size. The ag tires are alot narrower and also not quite as tall. If you can use them, I'll take $250 for the set.(they're 90% tread with no dry rot)...........LEMME know.............Tom
Tom,
I am familiar with the Rice Paddy Tires. They do have an aggressive tread but they should not cause me any problem because I use this tractor at my hunting camp and in the woods around the house.
There are 6 lugs on the rear wheels on my tractor with a 3" center to center dimension. Can you check your tractor for that dimension?
Do you have a way to ship the wheels & tires?
Thanks for responding.
   / Kubota L185 "R1" Agriculture Tread Tires for rear. #4
Picture of tires & wheels. my guess is they weigh in at about 80 lbs each so both with a pallet should be 200# or less. I have a business address on a state route so any trucking co. would be able to pick them up. i sell mainly forklifts so I don't use trucking companies to normally ship anything out. you may have to call around for a quote, unless you know a friend who trucks to ohio.
   / Kubota L185 "R1" Agriculture Tread Tires for rear. #5
Pic of lug measurement
   / Kubota L185 "R1" Agriculture Tread Tires for rear. #6
accross center
   / Kubota L185 "R1" Agriculture Tread Tires for rear. #7
Height/diameter pic
   / Kubota L185 "R1" Agriculture Tread Tires for rear. #8
Center hole pic
Tom,
Looks like everything will work. I will buy the wheels and tires. My email is "constructionloua@bellsouth.net". Contact me through email and we will work out the details.
Thanks loads!
Mikey
   / Kubota L185 "R1" Agriculture Tread Tires for rear. #10
Mikey......Sent you an e-mail...........Tom
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A53472)
Greenworks...
2021 JOHN DEERE 8R250 LOT NUMBER 193 (A53084)
2021 JOHN DEERE...
66in Light Material Bucket Skid Steer Connection (A53472)
66in Light...
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
2004 Ranger 195 VX Comanchee Bass Boat with Trailer (A51573)
2004 Ranger 195 VX...
