Kubota L185 "R1" Agriculture Tread Tires for rear.
   / Kubota L185 "R1" Agriculture Tread Tires for rear. #1
MikeyG
Alabama
Kubota L185 \"R1\" Agriculture Tread Tires for rear.
First of all thanks to Kuby for the info on the loader hookup. I used and abstract version of your set up and it works great.
My L185 came with 13.6 x 16 Turf Tires. I can not find that size AG Tire. I need a set of AG Tire wheels for this 2WD tractor. Or, I need to know if anyone knows a better way to do this. Wheels are 6 lug with approximately 3" lug to lug.
Thanks, MikeyG
   / Kubota L185 "R1" Agriculture Tread Tires for rear. #2
Re: Kubota L185 \"R1\" Agriculture Tread Tires for rear.
Mikey.......I have a set of original tires & rims off my grey market kubota L1500DT. That model is equivelent to the US L175 model. They're ag tires but very aggressive tread for the rice patties in japan. I took them off and put turfs the same size as you're running on your tractor now. Attached is a picture of my tractor with the turfs on so you can compare the size of my tractor and yours. I can get a picture of the ag tires & wheels tomorrow if you think the tractors are comparable in size. The ag tires are alot narrower and also not quite as tall. If you can use them, I'll take $250 for the set.(they're 90% tread with no dry rot)...........LEMME know.............Tom
Tom,
I am familiar with the Rice Paddy Tires. They do have an aggressive tread but they should not cause me any problem because I use this tractor at my hunting camp and in the woods around the house.
There are 6 lugs on the rear wheels on my tractor with a 3" center to center dimension. Can you check your tractor for that dimension?
Do you have a way to ship the wheels & tires?
Thanks for responding.
   / Kubota L185 "R1" Agriculture Tread Tires for rear. #4
Picture of tires & wheels. my guess is they weigh in at about 80 lbs each so both with a pallet should be 200# or less. I have a business address on a state route so any trucking co. would be able to pick them up. i sell mainly forklifts so I don't use trucking companies to normally ship anything out. you may have to call around for a quote, unless you know a friend who trucks to ohio.
   / Kubota L185 "R1" Agriculture Tread Tires for rear. #5
Pic of lug measurement
   / Kubota L185 "R1" Agriculture Tread Tires for rear. #6
accross center
   / Kubota L185 "R1" Agriculture Tread Tires for rear. #7
Height/diameter pic
   / Kubota L185 "R1" Agriculture Tread Tires for rear. #8
Center hole pic
Tom,
Looks like everything will work. I will buy the wheels and tires. My email is "constructionloua@bellsouth.net". Contact me through email and we will work out the details.
Thanks loads!
Mikey
   / Kubota L185 "R1" Agriculture Tread Tires for rear. #10
Mikey......Sent you an e-mail...........Tom
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2024 CATERPILLAR 255 SKID STEER (A51246)
2024 CATERPILLAR...
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
2012 Ford E-150 Passenger Van (A51692)
2012 Ford E-150...
2015 JCB 525-60T4 5,500lb 4x4 Rough Terrain Telehandler (A51691)
2015 JCB 525-60T4...
