Kubota L175
/ Kubota L175 #1
airbear
Pineville
L175
My very old L175 is having an oil pressure problem. It will start oil light goes out it will run for a moment, then the oil light comes on, idle or reved up, the lite stays on????? I think that if it were the pump, the light would not go out. I wonder if a port is stopped up and for a moment the pump pressures up and when runs out of oil and the light comes on. shut it down and start it back up, light goes out for a moment then comes back on...... any ideas????? thanks
/ Kubota L175 #2
I think I would replace the oil filter, make sure oil level is good, fit a pressure gauge to see what the oil pressure really is and if still a problem, drop the oil pan to look at the oil pick up screen and tube. Easy job-just had my L225 oil pan off due to a plugged oil screen. Cleaned and all is well.
Could also just be a weak oil pressure switch.
David
/ Kubota L175
David
Good tip , many thanks
1990 FRUEHAUF 53' DRY VAN TRAILER (A65054)
1990 FRUEHAUF 53'...
Case 90XT Skidsteer Loader (A66285)
Case 90XT...
2012 Komatsu PC200LC-8 Hydraulic Excavator (A64194)
2012 Komatsu...
2010 Workhorse Custom Chassis W62 Delivery Truck with Liftgate (A64556)
2010 Workhorse...
Landhonor Mini Skid Loader (A66285)
Landhonor Mini...
Cub Cadet 5252E Riding Mower (A65579)
Cub Cadet 5252E...
