Kubota L1501 overheats
   / Kubota L1501 overheats #1
podieroe
Sale Creek Tn
gravely 5260
L 1501 tractor overheating, fresh oil, clean radiator, cannot find a cause.Please advise!
   / Kubota L1501 overheats #2
Hello podieroe, What is the water level in the radiator? If you are loosing water , do you have a cab? If so check the heater hoses. I had a water loss situation due to a chafed heater hose.
"Clean radiator" ??? does that include blowing out the fins with compressed air to remove the dust? You will be amazed at the amount of dust a radiator can hold. When I drove for a hay contractor , a daily blow out of the radiator
was eccential or at mid afternoon on day 2 you would over heat due to a dusted up radiator, and the front would still appear clean.
More info would be a big help.
Cab or open station model?
Work /circumstances that over heating occurs?
Age?
Did over heating just start or has the tractor a history of running hot and now overheats?
   / Kubota L1501 overheats #3
Not familiar with that model so don't know if it has a water pump or is convection (thermo-siphon) cooled.
Fan and fan belt in good condition and working?
If equipped with a water pump, pump working, not leaking, thermostat installed and working?
Hoses in good shape, not collapsing?
Proper coolant mixture, not just plain water?
Interior of radiator clean as well? No plugged cores or scale floating around in the tank?
Signs of air bubbles or oil in the coolant (head gasket issues)
   / Kubota L1501 overheats #4
A plugged radiator is the most likely cause. Is the radiator filled with coolant? If the tractor is old the fins could be rusted off in the water pump. The fan belt could be loose, and not turning the fan and water pump.
2121 (A51244)
2121 (A51244)
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
2011 Jeep Grand Cherokee Laredo 4WD SUV (A50324)
2011 Jeep Grand...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
