Kubota L1500 won't start!
   / Kubota L1500 won't start! #1
alclpost
Kubota L1500
Hey everyone, New here and looking for some advice!
I just recently bought a Kubota L1500 for small projects and maintenance around the yard. It has been running just fine the first week I've had it. WELL I let my wife "TRY" to park it in the garage, long story short, by the time I got to her to pull the kill, she had put the front end loader through the wall. Not a huge deal, some new sheetrock and it will be good as new.
But now the tractor won't start. There is no damage to it at all, the loader protected everything. When I try to start it, once the coil lights up all I get is click, click, click, click until I let off the ignition. The first time I try to start it once it has been sitting I get about 1/10th of a fan blade turn, but the others I just get the clicks. Starter? Any ideas or help? Please!?
Thanks
   / Kubota L1500 won't start! #2
How much do you wanna bet that your negative post on the battery has worked itself loose or happened with the "accident". It happens once every year or so around here.
   / Kubota L1500 won't start! #3
Thanks
Check if it has spark
   / Kubota L1500 won't start! #4
i agree with the idea that a cable has come loose, look at the battery and follow the positive cable to the solinoid, the click may be from insufficient power to the solinoid, or even to the glow plug. also check to see that the battery was not damaged.
2022 BUCKEYE BMH CAR HAULER TRAILER (A52141)
2022 BUCKEYE BMH...
2019 MACK GR64F TANDEM AXLE CEMENT MIXER TRUCK (A52577)
2019 MACK GR64F...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A52128)
Koyker Loader...
2018 CATERPILLAR 336FL EXCAVATOR (A52141)
2018 CATERPILLAR...
2006 CATERPILLAR 320CL EXCAVATOR (A51242)
2006 CATERPILLAR...
2012 John Deere Gator HPX 4x4 Utility Cart (A51691)
2012 John Deere...
