Kubota L1500 will not start
   / Kubota L1500 will not start #31
stupidly run out of fuel
Fellows, this is not true. One runs the tractor out of fuel so the bottom of the tank can be checked for debris.:D
For the bleeding as per the [ Charlz, KJM ] last two posts. My B7100 acts requires exactly the same procedure.:D
   / Kubota L1500 will not start #32
What a huge relief! I don't feel so stupid anymore! If only I hadn't done it just when the mates arrived on the scene....:eek:
charlz: I know the operators manual says to crank to bleed, but the workshop manual doesn't and I didn't when I changed the filters. The pump top is below the tank level, so it does weep fuel nicely. Cranking gets the air out instantly(-ish) however.
-Kevin
2018 VOLVO VNL SLEEPER (A51222)
2018 VOLVO VNL...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
POWER BNG2800IE INVERTER GENERATOR (A50854)
POWER BNG2800IE...
100 GAL L SHAPED FUEL TANK (A50854)
100 GAL L SHAPED...
2011 V.E. ENTERPRISES 130 BBL STEEL VACUUM TANK TRAILER (A50854)
2011 V.E...
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
