Tires Kubota L1500 (US model 175) Filters & Tires
   / Kubota L1500 (US model 175) Filters & Tires #1
JGD
Florida panhandle
Kubota L1500 (grey model US equivalent L175)
I'm back after four months offline. Following is xref information that I have confirmed for my tractor:
Oil Filter
Napa 1034
Wix 51034
Fleetguard LF655
Fram PH2825
Air Filter
Wix 46270
Fram CAK8429
Fleetguard AF1658K
Fuel Filter
Napa 3390
Wix 33390
Fleetguard FF5226
Fram P7514
My rear tires, which are "unserviceable", are identified as follows:
Bridgestone Farm Service Lug Special 8.3/8-22 4-Ply Rating H. T. Nylon "For Japan Only". I've located this tire for sale at a place called hoyetractor.com and have learned that they have a turf tire size 9.5-22 that will fit my wheels. Several months ago, a Firestone rep on line told me the same thing. I'm about to order a set of these far less aggressive 9.5-22's--does anyone believe that this tire will not fit my rims? Does anyone know a good place to buy used tires of this size?
Thanks.
Follow-up note: Yesterday, I went to a local "chain" auto parts store and found/bought and then installed the following Purolator filters:
Oil Filter:
Purolator L20064
Fuel Filter:
Purolator F50262
Perhaps all other L1500 owners already knew all this, but I didn't and was happy to learn that there are some good, low cost options out there in terms of filters for my recently acquired old tractor!
   / Kubota L1500 (US model 175) Filters & Tires #3
Thats great info , i'll Have to print that post for my shop wall.
Its a great little tractor tha L1500
Todd
   / Kubota L1500 (US model 175) Filters & Tires #4
Where did you xref your numbers at car quest crossed them and matched the air and fuel but the oil all came up as a screw on filter. my L1500 has a canister filter for the oil.
Anyone know a reference number for the canister oil filter for the L1500 Z750.
Thanks todd
I used a number of sources to cross reference the filters and then bought 2 different brands of both fuel and oil filters. I simply cross referenced the known numbers I had in service using every filter company I could find on the net and came up with that list. Yes, my fuel and oil filters are screw-ons and I've since learned that some folks have/use cannisters. I'm staying with my screw-ons. Still haven't found the deal I want on the turf tires, but I'm close.
   / Kubota L1500 (US model 175) Filters & Tires #8
Just wanted to warn that the above mentioned 51302 filter is too long for my L1500 canister type application.
Update: The proper canister filter for the L1500 is a WIX 57030 filter. It is an exact replacement for the original. NAPA can cross reference it.
Profnohair
   / Kubota L1500 (US model 175) Filters & Tires #9
I have the L1500 and have discovered the wix has discontinued the 57030 oil filter. Napa cannot find any suitable replacement. Does anyone know where to purchase the adapter to change over to screw on or where to find the original canister filter. Also looking for front tires. I have Firestone AT Field and Road 6-14. All my local dealers tell me they can’t come up with a tire using the 6-14 number. Help appreciated.
   / Kubota L1500 (US model 175) Filters & Tires #10
I have an L1500 (Australia) and was told by the previous owner Ryco R2652P was a suitable oil filter. I've not bought one myself... yet.. so cant confirm further.
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A52748)
Koyker Loader...
2015 Kubota RTV-X1100C (A52748)
2015 Kubota...
2011 TROXELL 130BBL (A52472)
2011 TROXELL...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A52748)
UNVERFERTH 330 -...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
