kubota l1500 cooling system
   / kubota l1500 cooling system #1
ruut
I recently purchased a kubota L1500. I noticed it was dumping coolant out of the over flow. I pulled the upper house and flushed the system. It looks to me that the water pump is not pumping. Thoughts, ideas, suggestions, I need to get this fixed soon.
   / kubota l1500 cooling system #2
L1500 doesn't have a water pump.......it uses the thermocycle principle for cooling. You must have a clean radiator & operable fan for this to work properly. Use a 50/50 mix of antifreeze & water & mix it thouroghly before you fill the radiator. If you overfill the radiator, it will flow out the vent tube till it bleeds off excess coolant due to expansion. If the L1500 overheats to a boiling condition, the vent tube has a built-in whistle at the end that you'll hear letting you know to check the cooling system........Tom
Thanks I really appreciate the info I feel alot better knowing that I don't have to replace a water pump.
   / kubota l1500 cooling system #4
I don't know about Kubota, but Yanmar only recommends 25/30% antifreeze in their thermosyphon systems. Less antifreeze = better circulation, and I would definitely recommend installing an aftermarket coolant recovery system. you want as much coolant in the system as you can get.
2019 Caterpillars 299D2 XHP SKIDSTEER (A51242)
2019 Caterpillars...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
Bad Boy Outlaw XP61 Zero Turn Mower (A48082)
Bad Boy Outlaw...
2012 GALLEGOS TRAILER 130BBL VAC TRAILER (A50854)
2012 GALLEGOS...
2011 John Deere 844K Articulated Wheel Loader (A50322)
2011 John Deere...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
