HorsPower
From what I have gathered, Kubota offered one style of front quick hitch (which I will refer to as the "old", or L40 style) hitch during the L40 series tractor era. This style front hitch used a triangular mounting system, which utilized a female receiving bracket on the implement side.
It appears that Kubota redesigned the front hitch system and began offering it with the introduction of the L60 series tractors. This new system (which I will refer to as the "new", or L60 style) utilizes 4 mounting points at the implement, and has more of a hook and pin design.
To make things even more confusing, it looks like Kubota offers an "auto hitch" upgrade to this "new" system, which allows the operator to remain in the seat when switching implements. For the sake of the below questions, lets assume the "new" style hitch is not upgraded with the auto hitch option.
My questions are:
Are there any benefits to the "new" front hitch system over the previous "old" system? Did they redesign the hitch due to design flaws or to address any particular failure points? It seems possible that the redesign of the base hitch may have only been required to facilitate the offering of the "auto-hitch" upgrade.
One advantage of the old style front hitch looks to be that it can remain installed on the tractor (no implement of course), while the FEL is also mounted.
Can the "new" hitch system be installed on an L40 series tractor? i.e. are the tractor-side mounting brackets the same? Alternatively, could the "old" style hitch system be installed on a L60 series tractor?
I am currently in the process of purchasing a L5740, which I plan to equip with a front hitch system. Instead of purchasing a L2195a (old style) or L4479 (new style) Kubota front mount snow blower, I would rather retrofit a 3pt hitch blower (Pronovost or other) to the front of the machine. A couple of reasons for doing this:
My questions are:
- Higher quality blower than the Kubota / Rad units
- Ability to have the versatility of
- front mount use- big storms, deep snow, many days of plowing driving forward, OR
- rear mount use- smaller storms when a plow on the FEL loader is better suited, but the blower can be mounted on the rear for moving piles, cleanup etc. Also, if the primary tractor breaks down, the 3pt hitch blower can be easily moved to another machine
